Is This Structural Or Can I Rip It Down? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 07:36 AM   #1
Rewards Points: 402
Is this structural or can I rip it down?
The purple overhang piece, it appears it's just there for the lights? We think it's ugly and want it gone (along with a bung of other things in this kitchen ) so I'm thinking of just taking it down.
RyanD is offline   Reply With Quote
Old 04-04-2013, 07:37 AM   #2
Its looking gud man dnt rmv it
navekool is offline   Reply With Quote
Old 04-04-2013, 07:40 AM   #3
Rewards Points: 13,712
You can take it down but how do you plan on lighting up that area once it's gone?
That purple paint is sure not helping to blend it in and not make it stick out.
Old 04-04-2013, 07:40 AM   #4
Rewards Points: 402
The one on the left is sagging a little too. Maybe move the pots into the ceiling instead?
Old 04-04-2013, 07:41 AM   #5
http://www.bing.com/images/search?q=...deas&FORM=IGRE
Old 04-04-2013, 09:49 AM   #6
Rewards Points: 3,130
This may be way more work that you think. The wiring for the lights probably runs through the soffitt. And there's possibly not enough room in that ceiling for pot lights. If it were me, I'd correct the sagging and paint the soffit to match the walls.
Old 04-04-2013, 09:54 AM   #7
Rewards Points: 402
I'll try that first, maybe it's the purple that is making me nauseous.
Old 04-06-2013, 02:09 PM   #8
Rewards Points: 27
Besides wiring, there may be pipes in that soffit. You can pull the can lights
out and look in there (using a mirror if necessary) to see what's up.
kreemoweet is offline   Reply With Quote
Old 04-07-2013, 09:57 AM   #9
Rewards Points: 236
yeah. that purple is just BAD.
Fix'n it is offline   Reply With Quote
Old 04-07-2013, 07:01 PM   #10
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Ding Ding Ding!
Yep, cut a couple inspection holes first to see what's in there.
Sir MixAlot is offline   Reply With Quote
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 08:11 PM
non-combustible structural framing hellonoko Building & Construction 6 05-03-2012 05:31 PM
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 04:30 PM
Opening up a load-bearing wall. Do I need a structural engineer? Ironlight Building & Construction 3 04-18-2011 11:03 AM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 09:24 AM
