Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-27-2012, 05:25 PM   #1
strongest adhesive - science project
What is the strongest substance for building a gingerbread house? and why?
1. liquid nails
2. tacky glue
3. elmers school glue
4. royal icing
sbarkhurst is offline   Reply With Quote
Old 01-27-2012, 05:37 PM   #2
the Musigician
DangerMouse's Avatar
Bubble gum would be best...... if you chew it first it stays good and sticky a long time!
What does this question have to do with DIY repairs?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
Willie T (01-27-2012)
Old 01-27-2012, 05:50 PM   #3
Knucklez's Avatar
i would use 2-part epoxy.
don't let the dog eat your ginger bread house
but probably the answer is the icing because the material does not desolve the gingerbread
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 01-28-2012, 06:29 AM   #4
Retired carpenter
Aren't you supposed to figure that out by yourself?
abracaboom is offline   Reply With Quote
Old 01-28-2012, 07:55 AM   #5
Super Moderator
Be kind of a waste to use a glue that is much stronger than the gingerbread---I'd use a home made icing.
This is a DIY site after all---
Try them all --take pictures--and get back to us---
Old 01-28-2012, 08:05 AM   #6
"Nail-Bender"
Glue for a gingerbread house?
Icing.
I've done it - works fine - and -
It's edible!
rossfingal
rossfingal is offline   Reply With Quote
Old 01-28-2012, 08:08 AM   #7
In a little over my head
Check local codes.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
DangerMouse (01-28-2012)
Old 01-28-2012, 08:37 AM   #8
the Musigician
Originally Posted by ratherbefishing View Post
Check local codes.
True! It'd be a real PITA to build one only to have the city come along and tell you to tear it down! ....especially if Hansel and Gretel are busy!
DM
Wrong adhesive? Smudgeboss Flooring 0 12-30-2011 07:21 PM
Timbertech Radiance Rail project Ranger1227 Project Showcase 7 07-29-2011 01:59 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
my floor refurbish project Knucklez Project Showcase 28 08-10-2010 09:14 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
