Stripped Toilet Tank Bolt - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 08:22 AM   #1
Stripped toilet tank bolt
I stripped a toilet tank bolt this weekend and now have no clue how to get it off. I'm not sure if I can cut it off due to the awkward location. advice is greatly appreciated.
Sh0eBag22 is offline   Reply With Quote
Old 03-23-2009, 09:05 AM   #2
Remodeling Contractor
Cut it off. sawsall is used, but if you have a multi-master tool it will be easier.
Old 03-23-2009, 09:10 AM   #3
RippySkippy's Avatar
Is this the bolt that holds the tank to the base? If it is...remove the seat and cut it off with a hacksaw between the tank and base....shouldn't take but a couple of minutes. Alternatively, you could use a nut splitter to remove the nut with-out sawing...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-23-2009, 12:51 PM   #4
thanks for the info... how does that nut splitter work?
Old 03-23-2009, 01:02 PM   #5
Back off the black bolt which pulls the cutter back into the "handle". Slip the open end onto the nut, hold the light gray piece from rotating while tightening the black screw that drives the cutter into the nut. They work well.
LMASD
Old 03-23-2009, 01:34 PM   #6
I was thinking that it cut the bolt head off, but it really digs in to the head allowing you to turn the bolt.
Old 03-23-2009, 01:36 PM   #7
Kinda...think of it more as splitting the nut from top to bottom...
LMASD
Old 03-23-2009, 01:40 PM   #8
I've used the nut splitters
They do work very well
Old 03-23-2009, 05:49 PM   #9
I had a problem similar to this and I drilled a small hole into one of the flat sides of the nut. Then i kept enlarging the hole with larger bits until the hole spanned the width of the flat!
Then I hammered a flat screw-driver in, that caused the nut to spread and was loosened enough to allow it to be removed with fingers.
The nut splitter is of course the easiest, but this method will work if you don't have splitter!
Old 03-23-2009, 06:38 PM   #10
Old School
Willie T's Avatar
No, Shoe... It goes on the other end of the bolt. And you never try to turn the bolt at all. This is like a chisel in a vise... it cranks down on the nut, forcing (cutting) itself right through the side of the nut, completely destroying it so you can just pull (yank, twist, pry) the "split" nut off the end of the bolt with a pair of pliers. This tool makes history of the nut. It's gone. Destroyed.
Willie T
Old 03-24-2009, 07:56 AM   #11
gotcha... i guess the name does make sense then...
I decided to just hacksaw the bolt off. I got so frustrated with it that I didn't even realize that was an option until it was suggested. terlet is fixed now. Thanks boys.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 07:54 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
toilet tank leaking econdave Plumbing 12 07-07-2008 07:17 AM
toilet tank burst BillD Plumbing 4 06-29-2008 11:49 PM
