Stripped Screws - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 06:38 PM   #1
Rewards Points: 150
stripped screws
I have to remove the glass in the door of my woodstove. There are plates with screws in them that hold the glass. I have been spraying the screws with WD 40 so tonight I tried to remove them, I got all but 2 out . The 2 that are still in are almost stripped. I am afraid I am about to really strip them out. Any tricks to get these out?
econdave is offline   Reply With Quote
Old 07-06-2009, 06:58 PM   #2
Try "PB Blaster". It is more powerful that WD40 at loosening screws. Most auto parts stores have it. You could also try the Grabit.
http://www.aldn.com/grabit/
HD sells them. Probably many other hardware stores. They actually work pretty good.
I would say try heating the surrounding metal or cooling the screw but that may crack the glass.
beerdog is offline   Reply With Quote
Old 07-06-2009, 07:50 PM   #3
Rewards Points: 150
I guess I could try heating since it is the inside of the woodstove door which is under intense heat. I will try PB Blaster first though. If that dont work I will buy the Grabit.
Old 07-06-2009, 09:35 PM   #4
Are you worried about stripping the threads or the screw-driver slot. (assuming a slotted screw)
If the screw-head is damaged, one method is to drill a hole into the center of the screw-head. A drill that is equal to the screw thread minor diameter is used.
With this method, the head pops off, allowing the plates to be removed. Then, hopefully, enough of the screw will be left, to snap Visegrips and twist the screw out.
If there isn't enough of the screw left to grasp continue drilling down through the screw, then 'tap' new threads using a tap of the correct size.
Old 07-07-2009, 09:19 AM   #5
Rewards Points: 150
screwed
well, the head broke off of one screw, the othere will brake too I am sure and the threads are stuck, I guess I have to drill out the rest of the screw and re-tap it. Do you think these are stainless steel screws because they are exposed to high temps inside the woodstove? Man this stinks.
Old 07-07-2009, 12:15 PM   #6
Hey! Thats why we do it ourselves because we love the challenge!
It possible, although stainless would be less likely to 'freeze' in the holes.
Old 07-07-2009, 02:51 PM   #7
Rewards Points: 150
No, we do it to save money. Sometimes I wonder if the aggrevation is worth the money. Thank you for you help and input on this matter though. This is a great website to gather advice and info.
Old 07-07-2009, 05:11 PM   #8
Rewards Points: 150
good news
I was able to back both screws out without having to drill. I can replace the glass and install new screws. Should I use stainless?
Old 07-07-2009, 05:23 PM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Yes , Go to a specialty Hardware. Forget the Home Centers. They don't stock anything unless they can sell a jillion a month.
Disclaimer
& Stay Safe
.....Bob Lavery
Stripped out door hinge screws krankykitty Carpentry 23 01-16-2012 09:23 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
