Stripped Screw On Wall Oven- Help! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2010, 08:45 AM   #1
Stripped screw on wall oven- Help!
The previous owner reinstalled a Jenn Air wall oven when doing a reno. He stripped the screw big time- it looks as if it was once a square head. How can I get it out? It is metal on metal and is slightly recessed so there is virtually no room to grab it with vice grips etc. I have sprayed it with Jig-a- Loo. A friend suggested a screw extractor- someone else said get a dremel and make a new slot. Opinions?
Pontiacgirl is offline   Reply With Quote
Old 01-16-2010, 09:03 AM   #2
Household Handyman
Rewards Points: 1,408
There's an old "trick of the trade" I've used many times, but you have to be careful and patient with this. Use a small cold chisel, 1/4" wide is plenty. Place the corner of the chisel on the head of the screw somewhere between the old driver hole and the outer edge, and angle the chisel away from the direction you want the screw to turn, at about 45 degrees. TAP, gently TAP, the screw in the CCW direction and see if this will loosen the screw. Others may chime in here and say they use a center punch, that's fine also, I'm just used to my way. Making a new slot with something like a Dremel is also a good idea and then use a flat screwdriver, IF you have a Dremel handy. Good Luck, David
Old 01-16-2010, 10:52 AM   #3
Civil Engineer
Rewards Points: 4,858
I have successfully removed screws using a screw extractor (sometimes called an easy out). You can purchase a set of these tools for under $20. They are hardened steel devices that look like screws, except they are reverse threaded. You drill a hole of a specified size in the screw you want to remove, tap in the easy out, then turn the easy out to extract the screw.
Word of caution. The hard part is drilling the hole in the screw straight, especially if the screw you want to extract is hard steel like stainless. You cannot do this using cheap drill bits, you are going to need very hard steel bits, typically titanium nitride coated, to drill stainless. Take your time drilling the hole, use the correct sized bit, and use a fresh, sharp bit to do the job.
Daniel Holzman is online now   Reply With Quote
Old 01-16-2010, 02:37 PM   #4
USing a drill bit that is slightly larger than the outside diameter of the screw head, drill into the screw head. This will demolish it completely.
Although this means that you will never get the screw out, it allows you to continue with the disassembly project that you started. And if you need to have a screw somewhere near there when you re-install, drill a new hole.
YesMaam27577 is offline   Reply With Quote
Old 01-16-2010, 03:04 PM   #5
The set of extractors i own are hardened steel, tapered and four sided. Depending on screw/bolt size i drill hole for appropriate wedge, drive the wedge in tight and remove with adjustable wrench
Old 01-16-2010, 03:47 PM   #6
I ended up buying both the screw style and the 4 sided style of extractor. I will return what I don't use. The crew head is about 1/2" in diameter so I don't think I will try drilling it out. I don't know how good a bit I have but I do have a dremel. I am sure something will work! Thansk for all the input. When I was at the store no one could tell me how to use the extractor so I was going to ask here. But between youall, I have the answer. Thanks!
Old 01-16-2010, 04:02 PM   #7
Too Short? Cut it Again!
I have the Craftsman screw extraction set. I have not found anything yet beyond it. Good luck.
Never use the screws that come with appliances by the way. They are absolute crap.
Old 01-17-2010, 08:54 AM   #8
Thurman/David, you hit the nail on the head, or in this case the screw, I've seen my boss do same as you said, works great. Also before starting, rap on the head a few times, vibrations work wonders. And, personally, most times I used the extractor, it wasn't pretty. In this case you are going to need to get the screw out if you are planning on keeping that appliance there.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-17-2010, 10:21 AM   #9
Wall oven is out and strangely enough the stripped screw was not a problem. It was just holding sheet metal to sheet metal- boy how dumb am I! Thank god I found out before I tried using extractor etc
Old 01-17-2010, 10:50 AM   #10
Household Handyman
"Pontiacgirl"--glad you "got er done", and at least you got to talk to us about it.
"Dude"--your boss must be as old as I am
Thanks, David
Old 01-17-2010, 11:04 AM   #11
Safe, Most of the Time!!
brokenknee's Avatar
I know the job is already done, but thought I would post a picture of the screw extractors for those that are not sure what they look like.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
change from gas wall oven to electric runjean Electrical 3 04-19-2009 02:04 PM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 04:45 PM
