Strange Wall Material Under Shower Tile - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-13-2006, 04:32 PM   #1
I was removing some tiles from the shower wall. They had begun to buckle and I suspencted some water was getting under them. The building is rather old (turn of the century,) and under the tile there was a thin layer of paint/plaster that had definitely seen some moisture. Under that was this grey material that initally looked like cement, but when I put a putty knife to it, it just crumbled like it was dirt! Does anyone know that this is, or more importantly how to prepare this surface to recieve tiles? Again, it's a shower, so moisture is an issue.
Thanks.
caphill is offline   Reply With Quote
Old 07-13-2006, 08:24 PM   #2
Contractor
In this era many were still building their own homes. Also they hired recent immigrants for this type of work, each had their own way of doing things. No building codes back then.
I could take a few guesses on what was used to set the tile (not that it matters) what ever is underneath it is anybody's guess. I could well be a mix of cement, horsehair, asbestos, local clays and anything else. Horsehair and asbestos were commonly used as binders.
Teetorbilt is offline   Reply With Quote
Old 07-14-2006, 06:21 AM   #3
It sounds like you have plaster and lath.
this must be removed because it will not hold the tile.
redline is offline   Reply With Quote
Old 07-14-2006, 08:44 AM   #4
I think there is eventually terra cotta bricks (hollow) under all the grey stuff. I understand that durock (sp?) is a good material to mount tiles on in a wet area, but in this situation, attaching it to the terra cotta could be tricky. Can I apply cement or some other hardening substance to the wall as a mounting surface for the tiles?
Old 07-23-2006, 09:50 PM   #5
How is the current material attached?
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 12:27 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 11:25 AM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 12:01 AM
