Strange Turnkey Sticking Out Of Floor. Can Anyone Identify? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 01:36 PM   #1
Rewards Points: 14
Strange turnkey sticking out of floor. Can anyone identify?
Greetings everyone! First time poster here.
Recently I needed to move an extremely large piece of furniture to prepare for our new baby girl. I've lived in this house for about 7years now, which is a split level made in 1959.
Behind this piece of furniture I found what looks like some sort of shut off key sticking out of the hardwood floor. Here's a pic.
http://m.flickr.com/#/photos/63438193@N06/6833566144/
I've got no clue what it is. Underneath this room is the garage. There is no visible pipe or anything I can see from underneath where it is. Also, if you look at the molding you can see a round dent where someone had obviously used a device to turn whatever this is.
This poses a danger to a baby so I need to remove it, unless it's important.
Can anyone help identify what this might be?
harryc is offline   Reply With Quote
Old 03-13-2012, 01:51 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
The link to your pic did not work.
Are you sure it's not a shut off for gas?
ddawg16 is online now   Reply With Quote
Old 03-13-2012, 02:04 PM   #3
joed's Avatar
Rewards Points: 12,852
It does not look like a shut off valve to me. It looks like some sort of capped off pipe. Without some sort of reference as to what might be found near it I could not even guess. If it MUST be remove then open the ceiling in the garage below and see where it goes.
Old 03-13-2012, 02:05 PM   #4
Rewards Points: 13,694
http://www.northlineexpress.com/item...term=5CO-47133
Does it look something like this?
Or does it really a key?
Old 03-13-2012, 02:06 PM   #5
Rewards Points: 14
Strange. The pic is showing up on my end when I click the link. What's its saying when you try to view it?
Old 03-13-2012, 02:12 PM   #6
JOATMON
ddawg16's Avatar
It's asking me to sign in flikr
Old 03-13-2012, 02:18 PM   #7
Rewards Points: 14
Lets see if I can upload it correctly...
I uploaded it in attachments. hopefully that worked.
Strange turnkey sticking out of floor. Can anyone identify?-6833566144_4306202ea6.jpg
Old 03-13-2012, 02:20 PM   #8
Rewards Points: 14
Its near nothing. If I go into the garage and look up exactly where it lines up theres nothing there. No pipe, nuthin!
Whatever it is must run underneath the hardwood flooring between the joists.
Old 03-13-2012, 02:45 PM   #9
Looks about where there could have been an old steam register.
Only way to find out is to cut out some sheetrock below.
Old 03-13-2012, 02:48 PM   #10
JOATMON
ddawg16's Avatar
That is my thought as well....it could be making a 90 deg turn and going into the wall which is why you don't see it below.
Old 03-13-2012, 03:44 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
That looks like a screw driver someone got stuck and pulled the handle off to me. How big is it?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
DangerMouse (03-13-2012), DexterII (03-13-2012)
Old 03-13-2012, 05:58 PM   #12
Rewards Points: 14
It couldn't be. It just couldn't be.
Now I gotta get a pair of pliers and try to yank on it.
Old 03-13-2012, 07:02 PM   #13
Rewards Points: 104
Good job, Jim! I do believe that you are going to the head of the class!
Old 03-13-2012, 07:43 PM   #14
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I still don't know.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-13-2012, 08:53 PM   #15
Rewards Points: 14
Not a screwdriver. Was a good guess though.
It's definitely attached to something solid like a pipe. It has absolutely no give to it in any direction.
The Following User Says Thank You to harryc For This Useful Post:
BigJim (03-13-2012)
