Strange Hole In The Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 03:42 PM   #1
Rewards Points: 77
Strange hole in the wall
In the downstairs family room, there is a piece of wood that was attached to the wall for reasons unknown. Finally decided to pry it off last night and it's covering a hole 18" x 3". This hole was perfectly cut and the board looks like it was made to fit in the hole for some reason or the other. Nothing unusual in the hole, just the studs, insulation and vapor barrier. It's probably 6 feet from the ground as well.
Will post pics later this evening but any ideas? We are getting ready to paint so I am just going to drill a piece of drywall and then crackfill any small gaps which will then be eventually painted.
elementz is offline   Reply With Quote
Old 01-13-2010, 06:17 PM   #2
Rewards Points: 77
Here are the pictures:
board on wall
See how high it is
Board removed
Different angle
Old 01-13-2010, 06:18 PM   #3
Rewards Points: 77
That hole was definitely cut out but I have no idea why it wasn't fixed when the previous tenants were painting as you can see the paint all over it. A real head scratcher.
Old 01-13-2010, 08:15 PM   #4
Learning by Doing
Leah Frances's Avatar
Heck, that's an odd one. Bump.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-13-2010, 08:23 PM   #5
did you look to see whats behind insol, valve, repair?
Old 01-13-2010, 08:27 PM   #6
Looks like a couple holes in the other wall right around the corner too
Old 01-13-2010, 08:41 PM   #7
Learning by Doing
This is a rental? Then it could be ANYTHING. Tenants are crazy.
Old 01-13-2010, 09:16 PM   #8
joed's Avatar
Rewards Points: 11,966
What is behind that bump out? Maybe they needed some access to a pipe.
Old 01-13-2010, 09:25 PM   #9
Rewards Points: 77
There are no other holes, those spots are just crackfilling over screws.
This is not a rental, this is a house I purchased back in October.
Behind the bumpout is the insulation, studs, and vapor barrier.
Old 01-14-2010, 11:43 AM   #10
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Any wiring run for surround sound speaker mounting? I haven't got a guess outside of that.
hyunelan2 is offline   Reply With Quote
Old 01-14-2010, 12:24 PM   #11
Rewards Points: 77
I was thinking that as well but that would have been kind of sloppy. You don't need to cut open a hole 18"x3" for a small piece of speaker wire.
Old 01-14-2010, 12:31 PM   #12
What else? Doesn't it serve some purpose?
Why is there no nailer in the corner? Has that been removed too? If so, someone went to a lot of work to make room for something.
pyper is offline   Reply With Quote
Old 01-14-2010, 01:43 PM   #13
Rewards Points: 77
There is an electrical outlet but thats about 3-4 feet down which is coming from the opposite wall. Not sure what you mean when you question why their isn't a nailer in the corner. From where the picture was taken, I am by the foot of my stairs going uptowards the side entrance way.
Old 01-14-2010, 08:56 PM   #14
In the "board removed" photo, look at the right edge. What was the right edge of the sheetrock nailed to? You can't put sheetrock into a corner without something to attach it to -- nothing to hold it in place as you try to put the mud into the corner.
Aside from the outlet, what's the purpose of this bump out? Does the exterior of the house follow the contour of the interior? If this bit on the inside is not followed on the outside, then someone framed it. Why? If there's no obvious answer, then maybe the hole has something to do with it -- maybe there's something in there that you won't find unless you tear it out -- a plumbing vent or some pipes or something.
I don't know what or why, but you don't just put something like that in without some kind of reason, right?
Old 01-14-2010, 09:54 PM   #15
jlhaslip's Avatar
Rewards Points: 922
Your vapour barrier is inside out. the writing is backwards.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Putting a hole in a wall without getting electrocuted. DirtAddsHP General DIY Discussions 14 04-23-2009 03:51 PM
A hole in the basement wall handifoot Building & Construction 10 01-08-2009 10:14 AM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
Strange Wall Material Under Shower Tile caphill General DIY Discussions 4 07-23-2006 10:50 PM
