Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-20-2009, 11:34 AM   #1
Straight Edge
Hi! I have a countertop that extends beyond the wall by about 6 inches and is not cut perfectly straight. The first 20" is tucked into an alcove (and so can be concealed with silicone) but I have to put edging on the last 6 inches and to do this I need it flat... I'm sure the contractor thought he'd fix it when he comes back. Which he's probably never going to do.
My question (sorry - rant rant rant) - what is the best tool for making this flat (particle board with a laminate top - thanks ron!) without pulling it out as it's tucked in pretty good. There's a variance of about 3/8ths of an inch.
Thanks!!
dedrie77 is offline   Reply With Quote
Old 05-20-2009, 02:42 PM   #2
Moderator
Straight Edge
Is a picture possible? Be safe, G
Old 05-20-2009, 04:11 PM   #3
Straight Edge
To cut it straight, you would use a circular saw with a 40 tooth carbide or a plywood blade. And a straight edge clamped to the counter.
But to avoid chipping the laminate, you need to remove the counter, flip it over and cut it from the back.
Ron
Drywall - butt edge to tapered edge Richo Drywall & Plaster 5 04-20-2009 10:33 AM
How to hang screws from soffitt - the underside of the outer edge of the roof Synthia212 General Discussion 5 03-10-2009 06:08 PM
Edge Flooringwhat the heck? sammythebull Flooring 29 03-28-2008 11:57 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 03:10 PM
