Stove Vent Doesnt Vent Very Well - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-19-2009, 12:46 PM   #1
stove vent doesnt vent very well
I have an older Jenn air stove with a grill on it. The vent doesn't work very well and I was wondering if anyone has any comments?
The fan seems to be working OK and the duct work seems fine as well.
Do these style of vents (intake is between the burners NOT overhead) just not work very well?
kalabula is offline   Reply With Quote
Old 01-19-2009, 01:36 PM   #2
Registered User
Termite's Avatar
Do you know where the vent is ducted to? I've seen people (and builders) vent them into the wall cavity or into very small parts of the attic that lack ventilation. The vent should terminate to the outdoors via the side wall of the house or the roof. If it doesn't, it may not be able to create any static pressure in the duct to carry the fumes outside.
Old 01-19-2009, 02:20 PM   #3
Its vented to the outside via a 5" dia. flexible duct. Its less then a 10' run. Also the when I went outside to check to see if the damper was opening (it was) and the pressure seemed really good.
Old 01-19-2009, 05:50 PM   #4
Had one
My father has one it it does not pull air all that well. I think its just par for the Jen Air model.
JCAHILL4 is offline   Reply With Quote
Old 01-19-2009, 06:02 PM   #5
Electrical Contractor
kbsparky's Avatar
Those are fine for grilling steaks.
But they don't work as well for venting fumes from a pot boiling on the stove top.
Old 01-19-2009, 09:42 PM   #6
I am having a problem with the grill side of the stove. I have to open windows after I grill. I am wondering what kind ov duct setup everyone else has. Mine has 6" flex hose going from the stove to the fan (all under the stove). Then in the basement there is another 10' of 5" flex that goes from the "out" end of the fan to the damper outside.
Old 01-20-2009, 01:22 PM   #7
Rewards Points: 5,336
The instructions from the manufacturer should dictate the duct size. Flexible ducts will restrict air flow more then rigid duct work. If you need to modify it, check with Jenn-air first to see you have the correct diameter piping.
Ron
Old 01-20-2009, 07:37 PM   #8
Learning by Doing
Leah Frances's Avatar
oooh - oooh -oooh. I just re-did my JennAir's ducting. It vents through the basement out a basement window (at some point I will drill a hole through the 18 inch thick brick wall ). The vent has about a 28 inch run through the basement.
The JennAir vent enters the basement with a 4 3/4 inch pipe that I figure was a custom-jobbie. I used a modified 6 inch to 4 inch reducer to run to the semi-rigid 4 inch vent.
As a chef, I think the vent is not adequate to remove heavy smoke or steam - I find it helps to use a splatter screen to direct the steam/smoke/etc toward the vent's intake. If you cook any greasy food I would suspect that your vent or filter are clogged. I find I have to clean my filter at least twice a month or it gets bogged down.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-20-2009, 08:31 PM   #9
remodeling pro
IMO. downdraft ranges, as well as the expensive units with the pop up vents behind the cooktop, have always been a disappointment in performance. When asked my opinion by a customer about these configurations, I tell them to think about them from a logical, engineering, position, rather than the marketing hype or asthestics sales pitch. The contaminants that you are trying to vent originate at the top of your cookware, anywhere from 4" to 12" or more above the cooking surface, and are naturally rising from the cooking heat. It just is not practical to pull enough air into a downdraft to be able to reverse their flow from this elevation without sucking all of the heat from the flame out due to the huge volume of air and high velocity that would require.
troubleseeker is offline   Reply With Quote
Old 01-20-2009, 09:19 PM   #10
Well as it happens, my dad found an old (but new) motor for the exhaust fan which I have since installed. Also I am removing all the 4" flex pipe and replacing it with rigid 5" pipe.
When I am done I will try and remember to post back with the results.
Thanks for all the good info.
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Adding stove top vent - cutting asbestos shingles t_mccann Building & Construction 6 11-29-2007 03:59 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 12:36 PM
