Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-17-2011, 11:12 PM   #1
Stove Removal Help - Plumber?
Hello,
I am a recent home buyer and just purchased a home with an old gas stove. I want to remove this from my kitchen and install an electric stove. However, when taking a closer look at the stove, I found it was connected to a vent that runs through the kitchen floor, to the basement and outside (see pictures).
My question is who do i need to hire that can come and uninstall the stove and connection in the basement? Would a plumber be appropriate for this? Thank you for your feedback.
mbaran79 is offline   Reply With Quote
Old 04-18-2011, 09:00 AM   #2
A plumber could do the job. I'd cap the gas line in the basement just under the stove's location. The vent could be removed by you if you want to save some money. The vent to the outside is too small and the wrong type "pipe", so I'd pull that out and fill the opening with another glass block or whatever that is.
Ron
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 08:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 02:14 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
