Storm Door Measurement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 02:57 PM   #1
Rewards Points: 14
I am about to purchase two Andersen 3000 Series Storm Doors from Home Depot, but i'm having trouble with the measurements.
I believe I have the standard 36" Front & 32' Rear entry doors in my house, but when I measure for the storm doors where the manufacturer's brochure says to it comes up 37" & 33" respectively. I think these doors use a Z-Bar frame.
I have included a photo of my set up & have measured from "B" to "B" which is what I consider to be the inside face of the brick mould.
I was hoping that standard 32" & 36" doors would work so that I would not have to special order at a higher cost.
Am I measuring correctly? Please advise.
winterland is offline   Reply With Quote
Old 08-17-2011, 03:06 PM   #2
Rewards Points: 6,652
Those are correct measurements that you got for the rough in opening. the actual doors are 32 & 36, but as you noted, the frame is 33 & 37. You have to allow for the frame of the door. As for where it gets placed, it is on the outside of the brick mold "a". Look at the examples at the store, and how your neighbors doors are. If you do not feel like doing the work, hire a contractor to install.
Before you install the doors, scrape, prime and paint the brick molding, and replace any caulk between it and the brick work on your house. I used a 15 year barn paint for my door frame, and it has stood up very well.
Old 08-17-2011, 04:10 PM   #3
Rewards Points: 14
Thanks for your answer Gregzoll. Are you saying that a standard 32" & 36" door will fit my 33"/37" opening from B - B ? The brochure states that a 32" door will only fit a rough opening of 31 3/4" to 32 3/8".
http://www.homedepot.com/Doors-Windo...kuId=202766805
http://www.homedepot.com/catalog/pdf...3688327fc0.pdf
Old 08-17-2011, 04:29 PM   #4
The frame sits on the outside brick molding, but you tak 3 horizontal and 3 vertical measurements from the opening as you did. You will be fine with standard sizes. Just like mine is mounted, is how yours will sit.
Old 08-17-2011, 09:39 PM   #5
Rewards Points: 133
Those doors will not fit your opening without adding additional wood. If you try to hang it on a 37" opening the lock side will be to far off of the brick mold. Add a 1/2" strip to each side of the opening. Get your openings as close to the size of the door as possible.
paul100 is offline   Reply With Quote
Old 08-17-2011, 11:08 PM   #6
Rewards Points: 5,336
On the storm door box will be the size of the opening the door will fit into. There will be a small range of openings listed, say 35 7/8"-36 1/4" wide and 79 1/2" -80 1/2" high. As long as your opening is within these parameters, the door will fit.
Ron
B. Franklin 1759
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 10:47 AM
34" Wide Storm Doors Custom Size Only? kc27 Building & Construction 3 12-08-2010 01:34 PM
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 09:17 AM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-22-2008 12:37 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
