Storm Door Hanging - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 04:14 PM   #1
Solutions (handyman)
Rewards Points: 364
Storm Door hanging
I am soon to install a storm dor with a kit. The kit allows me to use the door and adjust the frame to fit. Question is, should the new door follow the existing frame, which is not plumb, or make the new door level and plumb?
Thanks. Mark
Mark Harvey is offline   Reply With Quote
Old 05-30-2010, 05:35 PM   #2
jlhaslip's Avatar
Rewards Points: 2,092
Plumb the hinge side and then set your margins to the door on the strike side.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 05-30-2010, 06:06 PM   #3
kwikfishron's Avatar
Rewards Points: 576
Your kind of limited with how much you can adjust the plumb of a storm door due to the narrow frame and the placement of the screw holes.
How far out of plumb are we talking?
kwikfishron is online now   Reply With Quote
Old 05-30-2010, 06:14 PM   #4
Rewards Points: 364
storm door frame
Instructions say up to 3/4" per side.
Old 05-30-2010, 06:24 PM   #5
Rewards Points: 576
You still didn’t say how far out you are.
If you end up with a "slightly out of plumb" storm door it will still function just fine.
Old 05-30-2010, 07:36 PM   #6
Rewards Points: 364
gottcha, Misundwerstood. ...Not too far out of plumb, but thought exact might be better than following the existing frame. The main door works fine. So, either way I should be okay.
Thanks.
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 08:17 AM
Storm door replacement Davidb6 Carpentry 10 05-18-2009 09:40 AM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-21-2008 11:37 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
