Storm Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 06:09 PM   #1
Rewards Points: 480
storm door
Since we've moved in our storm door has seemed off a bit. Seems like a dumb question, but is it supposed to open 90 degrees? Ours definitely isn't opening wide enough. Before I adjust the top piece (safety chain?), I want to know how much I should expect the door to open..Thanks
joetab24 is offline   Reply With Quote
Old 02-17-2010, 07:09 PM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
It may be the door closer. I've noticed certain models have a shorter travel from the rod into the cylinder. Unhook the chain and open the door watching the rod. It may stop short of 90. If not, it is a chain adjustment.
I know from experience that a top brand from Menard's changed to the shorter closer. If you install it according to their specs, the door will not open to a 90 degree, more like a 75.
Kevin
Kevin M. is offline   Reply With Quote
Old 02-17-2010, 07:48 PM   #3
Rewards Points: 5,336
It might also be the way the closer was installed. The bracket on the frame should be 1/4" away from the storm door frame. The closer should be attached to the door about 18" from the hinge side edge. If the closer has been attached at 20", the doors opening will be reduced.
Ron
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 09:17 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Storm Door Handle Installation jogan General DIY Discussions 3 06-09-2009 10:57 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
