Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-06-2013, 03:08 PM   #1
biggles's Avatar
storing screws and drill bits
coffee cans,glass jars been there done that.......25yrs later seems to be the best deal... who doesn't drink milk stick the bit in the plastic till the next jobs up on that shelf in the cave...
The Following User Says Thank You to biggles For This Useful Post:
TheEplumber (06-06-2013)
Old 06-06-2013, 03:26 PM   #2
creeper's Avatar
That looks like a good use for those jugs. Our milk is not sold that way.
Are those edges sharp like other plastic packaging?
Are those jugs recycleable or do you get a deposit on them??
creeper is offline   Reply With Quote
Old 06-06-2013, 04:41 PM   #3
Old School
Willie T's Avatar
Not recycleable for money. A bit "floppy" when cut like that, too.
Willie T
Old 06-06-2013, 05:07 PM   #4
biggles's Avatar
no deposit and they are solid once the screws get dropped in......JEEEEZZZZZ..non sloppy
Old 06-06-2013, 05:09 PM   #5
Too old's Avatar
What I prefer using for all sorts of things like these is peanut butter jars. I can see through them and you can stack them too. I also use larger plastic jars that peanuts came in, to keep PVC pipe fittings. Again, can see through them and you can stack them too.
Too old is offline   Reply With Quote
Old 06-06-2013, 06:00 PM   #6
Old School
Willie T's Avatar
Sorry, Biggles..... They are only "solid" if pretty full of screws. With just a couple of handfuls of screws in them, and they flex quite a bit.
The Peanut Butter jars are fantastic. I must have 100 of them.
Willie T
Old 06-06-2013, 07:36 PM   #7
For the bits you use in the cordless drill, drywall bits, square drive bits, torx bits ect. an altoids can in your tool belt
Old 06-08-2013, 01:53 AM   #8
This is a good idea, sometimes we can save money doing this restoration. I collect helpful junks. However, remember the flipping properties boom before the economic downturn hit, where many people turned over run-down houses and sold them? It's making a small return lately, as investors were able to grab a ton of houses for dirt affordable and now are starting to see a bit of a payoff.
jomartan is offline   Reply With Quote
Stucco Mortar Mix OK to drill Tapcon screws into? miamicuse Building & Construction 1 11-18-2012 08:10 PM
Using regular drill for tapcon concrete screws? crayola110 Concrete, Stone & Masonry 5 10-10-2012 04:41 PM
Tough Drill Bits miamicuse Carpentry 12 01-14-2012 06:40 PM
screws not going in door frame with cordless drill lcw General Discussion 18 11-04-2010 01:06 AM
Drywall screws? Fine or coarse, tip for my drill yummy mummy Building & Construction 31 09-27-2007 03:15 PM
