Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-12-2012, 03:24 AM   #1
Stopwatch Trigger Help
Hey guys...
I'm doing a study for my university on hands-free cell phone use vs. hand-held use, while driving. I'm designing a traffic light that will light green and red. I'll be using a 3-way switch: red - off - green. When switched to red, I want a stopwatch to start. When the participant presses the brake pedal on our device, I want the stopwatch to stop. This will measure participant reaction times under different conditions (no phone, hand-held conversation, hands-free conversation).
I can create a light that works with a 3-way switch, but that's about the limit of my knowledge. Does anyone have any idea on what type of timer to integrate into this system, and how to go about start/stopping it with the switch/pedal?
Any suggestions on how to set this up would be great.
Thanks.
inhalexhale is offline   Reply With Quote
Old 10-12-2012, 08:09 AM   #2
JOATMON
ddawg16's Avatar
You don't want to be using a stop watch.....you need a digital timer.
They make plenty of them....here is one example
http://www.stopwatchcentral.com/ultr...akA.htm#Ultrak L10 Timing System
Unless your looking for real cheap....then you might want to look into kits...a good example is the timing kit for pinewood derby cars...
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 6 03-21-2012 02:26 PM
How to Install Trigger mechanism in Bostitch Coil Nailer pyrotek Tools 3 12-02-2011 09:08 AM
carrier furnce isn't lighting, cover must be installed, but can't find where trigger Elitecustomsurf HVAC 0 10-19-2011 10:17 PM
please help me before i pull the trigger... DangerMouse Building & Construction 15 09-06-2008 06:48 PM
what's wrong with my drill? kawak Tools 8 11-22-2007 11:17 AM
