Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-17-2008, 05:27 PM   #1
stone veneer
I wish to install some stone veneer or faux stone over james hardee board
siding on a new manufactured homes front entry area, the siding and home are pretty sturdy and well made. should i use a certain brand of stone veneer ?
stone paneling seems over priced. I am a do it yourselfer but i'm not afraid
of a project.
Thanks to all that reply........
dinodon is offline   Reply With Quote
Old 06-17-2008, 06:31 PM   #2
stone veneer
I would look at a few companies that sell the product and see what they consider an adequate substrate. Your siding might be sturdy, but will it be the correct base?
Ron
Old 06-20-2008, 05:26 AM   #3
CareBear
stone veneer
I don't think placing stone veneer directly over HardiPlank is a very good idea. Why don't you just remove the plank, put appropriate substrate board (just ask your rock dealer) over the newly exposed surface, and put the stone on that? That's much better and won't take very long to do.
CareBear is offline   Reply With Quote
Old 06-20-2008, 08:46 AM   #4
RippySkippy's Avatar
stone veneer
CareBear is right...remove the siding, and build it up correctly. Do it once and do it right.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-23-2008, 09:21 PM   #5
remodeling pro
stone veneer
Whatever brand you decide on must be installed per the manufacturers recommendations or the warranty will be void. That includes the recommended back substrate, proper detailing of flashings, and adhesives. I suggest you look around at local masonry dealers who carry the product, there is a lot of variation among the brands as to how convincing they are to the real thing, from almost impossible to distinguish, to phony from a 1/4 mile away.
troubleseeker is offline   Reply With Quote
Old 06-23-2008, 09:27 PM   #6
CareBear
stone veneer
Do you have any opinions about what brands or types are more convincing than others? I am considering the Eldorado Rustic Ledge for my current project.
Old 06-27-2008, 07:06 PM   #7
stone veneer
This is an, "eye of the beholder " thing. Go to the local masonary supply retailers and look at them.
Ron
Old 07-01-2008, 08:39 PM   #8
remodeling pro
stone veneer
IMO, no one manufacturer has the best looking of every type of stone. Try to find a supplier that might carry a couple manufacturers, so you can see your type selection from different manufacturers. Even if you have to visit a couple of suppliers, it is time well spent; when you see the one that your taste likes, it will jump out and make an impression on you over the others.
stone veneer on fireplace timber Building & Construction 23 12-20-2007 02:37 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Stone veneer over foam board. rfjm58 Building & Construction 6 04-10-2007 07:40 AM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
