Stinky trash can
Boil some water, pour into the can, put in a cup of Tide detergent, and start scrubbing. Then turn upside down and let dry. Should smell really clean after that. Of course, also depending on the age of the cans, and if they are out in the weather all the time, the plastic can absorb odors from whatever is put into them.
If you can get the can out of the garage, put it outside, instead of stinking up the garage all of the time.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
