Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-04-2008, 10:11 AM   #1
Sticking Sliding Door
I have a sliding patio door that opens smoothly from the inside but sticks occassionally from the outside. I was wondering if I clean out the track is it ok to spray it with some WD-40 or is there something else I should be using to ensure a smooth slide?
jte1130 is offline   Reply With Quote
Old 05-04-2008, 03:42 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Dry Graphite, which you can pick up from Lowes, Ace Hardware, Menard's, etc.
Old 05-04-2008, 06:00 PM   #3
I found dry graphite to work wonders on such sticky situations, especially sliding doors. I have a super heavy vinyl door with no runners. Spraying WD40 or any other "wet" oils will also attract dirt and dust in no time....trust me from my experience.
I also tried the good old fashioned SC Johnsons wax paste. It comes in a large metal tin and works great on everything. I wiped it all over the bottom and top rails and after several minutes wipe it dry. It will leave a residue that is dry and lubricated. It works well and doesn't pick up dirt.
I also use this stuff on tools, saw blades, and anything that could be improved by reducing friction.
DK75 is offline   Reply With Quote
Old 05-07-2008, 09:01 AM   #4
Great, thanks for the info. I'll give the dry graphite a try.
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
Garage Door Sticking wemwem General Discussion 1 01-22-2008 03:34 PM
weather stripping sticking to my new door? joeyboy General Discussion 1 12-02-2007 02:43 PM
Sliding Patio Door Installation flyultralite Building & Construction 11 05-04-2007 12:06 PM
