Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-01-2006, 03:53 PM   #1
Stairway loose
Hi All,
I have a steel stairway that is attached to a hollow brick wall.
In several locations, the bolts slip right out, and the stairway
is not held against the wall (it now shakes).
The holes in the metal of the stairs is 3/8, and the hole in the
brick behind the metal strip is larger than that.
I cannot pull the stairway away from the bricks more than 1/4 inch.
What would be the best way to re-secure the stairway to the brick
wall?
TIA
alan
asegal is offline   Reply With Quote
Old 12-02-2006, 09:11 AM   #2
Stairway loose
With out a photo it is hard to tell what you have.
But you may be able to put mortar into the holes where the bolts are loose to secure the bolts to the wall.
redline is offline   Reply With Quote
Old 12-02-2006, 03:16 PM   #3
Stairway loose
Here is a picture of stairs.
brick (hollow - so it can't be filled in with cement) is on the left.
Two holes are where I removed two lag bolts (loose - can't
tell what it went into)
--alan
Old 12-02-2006, 03:57 PM   #4
Master Craftsman
Big Dave's Avatar
Stairway loose
Since your not looking for a structural attachment just a movement attachment I would use a toggle bolt. They come in different sizes. You need to get one that will fit through the hole in the steel. You will have to get a washer big enough to keep the head from going through the hole and you will have to take the wing part off and put the washer on then reinstall the wing and place through the hole. The wings will open up and allow you to tighten it up holding the stairs tight to the wall. Here is a link to what I'm talking about.
http://www.ameribestfasteners.com/toggle_bolts.htm
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 12-02-2006, 05:00 PM   #5
Stairway loose
The toggles were my first thought, but then I thought the brick
would crumble... but with the steel piece right in front, it should work.
Thanks!
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Loose Driveway flyultralite Landscaping & Lawn Care 6 04-26-2007 09:32 PM
Stairway Help Needed ilikegolf Building & Construction 5 03-13-2005 03:32 PM
