Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-11-2009, 05:39 PM   #1
Stair Handrail Question
This may be just a matter of preference but I am remodeling my basement and and going to add a handrail in the stairwell. There was not one there before. I did not really think of it before but is there a proper side to put this handrail. I feel like it should be on the left side as you are walking down. This may be because that is how it was in my other house and that's what I am used to. Please let me know if there is a "correct" side to install this handrail. Thank you,
Rob
RobandStacey is offline   Reply With Quote
Old 01-11-2009, 08:40 PM   #2
Also, I ask because on one side is a cinderblock wall. On the other is a framed out wall that I built. Thanks
Old 01-11-2009, 09:56 PM   #3
Preference.
JCAHILL4 is offline   Reply With Quote
Old 01-11-2009, 11:43 PM   #4
Theres more then one way.
iMisspell's Avatar
Not sure about which side, but there is a height which it needs to be at; in NY it has to be between 34 and 38 inches from the step and has to be 1-1/2 inches away from the wall.
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience -
- Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 01-12-2009, 12:29 AM   #5
Moderator
Termite's Avatar
Imisspell is correctly quoting the International Residential Code.
On your basic staircase you can place the handrail on either side.
Here's a great resource for you to understand how the height is measured and how the handrail should be positioned. Click the blue link under the red writing.
http://www.stairways.org/codes_standards.htm
Old 01-12-2009, 12:32 AM   #6
Thanks guys. I was guessing it was just preference but when my brain gets going I can get stuck on the small details. Appreciate the height info too but I had already looked into that one and found answers easily. This is why I love this site, so I don't sit up at night worrying about the small stuff.
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 06:21 PM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Stair lighting question...help! Mary Ann Electrical 2 11-04-2008 12:21 AM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 09:02 AM
Stair riser protection question JLam Carpentry 3 09-11-2006 05:28 PM
