Stains On Polished Porcelain Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-23-2007, 08:00 PM   #1
Stains on polished porcelain tiles
Hi,
Just found this great forum.
I have just got my kitchen tiled using polished porcelain tiles. The job looked great after the tiler finished. However when the kitchen Guys or plummer had finished there were a number of black lines on the floor which look like those left from black soled shoes. I have tried to remove the stains using normal cleaners but they will not budge. Anyone have any experience with this or able to recommend a product to remove the stains
Best Regards
Tom
tommurphy73 is offline   Reply With Quote
Old 12-23-2007, 09:04 PM   #2
Oldguy
Rehabber's Avatar
If it is black marks from shoe soles, charcoal lighter fluid will remove it quickly. Just don't light it
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-24-2007, 06:37 AM   #3
try some wd-40 / or goof off.. + elbow grease
Big Bob is offline   Reply With Quote
Old 12-24-2007, 08:57 AM   #4
Thanks for the replies guys. Since I did not have any lighter fluid I used the wd-40 and elbow grease method which removed all the stains completely. The floor looks great now. All that is left to do is seal the tiles.
Thanks again
Best Regards
Tom
Old 12-24-2007, 01:03 PM   #5
Rewards Points: 5,336
"All that is left to do is seal the tiles."
You only need to seal the grout, the porcelain tiles don't really absorb anything.
Ron
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Porcelain Garage Tiles? head_dunce Flooring 6 02-22-2007 04:28 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
