Stained Cement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 08:15 PM   #1
Rewards Points: 150
stained cement
Hi,
Changed my furnace recently, and there was some "metal dust" on the floor, swept it up, threw it out in the trash, but I must have leaked and stained my front cement walkway. Any suggestions to get this off? CLR, Acetone?
Thanks!!
sbmfj is offline   Reply With Quote
Old 08-25-2011, 07:46 AM   #2
Rewards Points: 5,336
Power washer with a concrete cleaner solution.
Ron
B. Franklin 1759
Old 08-25-2011, 09:25 AM   #3
amuffly's Avatar
You could try a stiff bristle brush and a bucket of hot water with "tide" and scrub.
amuffly is offline   Reply With Quote
Old 08-25-2011, 10:30 AM   #4
Too Old
I have had some luck with using vinegar, let is set for 15 or 20 minutes first, if you have TSP try that also, or a light acid wash.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 08-25-2011, 10:14 PM   #5
Rewards Points: 150
thanks for your help. Used TSP and its helped allot.
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 06:30 PM
Applying Sprayed Stained Cement to Durock drarthur25 Building & Construction 3 12-15-2010 07:13 AM
Certainteed Fiber Cement Stained Cedar labriola Building & Construction 0 12-21-2009 04:29 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
