Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-05-2009, 12:30 PM   #1
Default Stackable washer and Dryer in hall closet
I just moved into an apartment. The small stackables are being removed and I am able to put my own Sears Elite stackables in closet. How do I go about doing this? They will fit. Do I stack them first and them move them in or what?
thatannegirl is offline   Reply With Quote
Old 11-05-2009, 12:58 PM   #2
ArmchairDIY's Avatar
I'm not familiar with that particular model, but I would assume stack them. Then make the connections of the water lines, dryer vent, and plug them in. Then slide them into place.
"It looked good on paper, but paper is funny that way"
ArmchairDIY
ArmchairDIY is offline   Reply With Quote
Old 11-05-2009, 01:53 PM   #3
Get someone to help you. Stackables are very heavy.
Old 11-05-2009, 03:25 PM   #4
You should put them on a moveable platform so you can access the exhaust vent for cleaning. They sell a wheel system that goes under refrigerators. It's under 1 1/2" thick.
Ron
Old 11-05-2009, 05:50 PM   #5
Make sure you determine just how much room you have for connecting them to the water, and vent supply first. It gets a lot closer then you think, when it comes to that part of this job. If they can be installed one at a time, I would do that. I did, and it saved me a lot of headaches.
Good luck!
Sheila4467 is offline   Reply With Quote
Old 11-05-2009, 05:53 PM   #6
Ron6519,
That's a great suggestion about the wheel platform, where can I get one?
I could use them for a lot of items I have, that need to be moved quite often.
Old 11-05-2009, 07:42 PM   #7
The big box stores used to sell them or you can do a search for, "appliance rollers".
Ron
Old 11-06-2009, 07:22 AM   #8
Thank you! I have to pick up a door lock today and I'll check on them then. Nice to have a name to ask for. "appliance rollers" Bless............
More On This Topic
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about proper use and maintenance of a pressure washer. As we mentioned, some pressure washers are gas and some are electric. Obviously... Read More »
Hi. My name is Matthew Christian, from Tampa Florida and on behalf of Expert Village, I'd like to talk to you about the use and maintenance of a pressure washer. Before you hook up your water supply, as we'll demonstrate in a moment, it's imperative that... Read More »
Hi my name is Matthew Christian from Tampa, Florida and on behalf of Expert Village. Today we are going to talk about the proper use and maintenance of a pressure washer. Okay another item to be familiar with as part of your pressure washer is the wand... Read More »
Hi my name is Matthew Christian from Tampa, Florida and on behalf of Expert Village. Today we are going to talk about the proper use and maintenance of a pressure washer. As I mentioned earlier the pressure washer that we are using today is of a... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a pressure washer. This section of the pressure washer is the pump. These are the cylinders... Read More »
Stackable Washer / Dryer Upstairs RammsteinNicCage Appliances 5 04-30-2009 07:23 PM
Moving Washer & Dryer to Closet beckt Plumbing 0 08-26-2008 04:16 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 1 03-04-2008 06:44 PM
Installing a stackable washer dryer in hall closet next to bathroom uncleb23 Plumbing 2 10-04-2007 09:51 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 11:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
