Squeaky Spring-hinges On Screen Door (WD40 Doesn't Last Long) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 03:12 AM   #1
squeaky spring-hinges on screen door (WD40 doesn't last long)
I have a back yard screen door that has spring-back hinges - hinges with springs that allow the door to close on its own.
They squeak quite a bit when the door is closing. Replacing them didn't solve the problem. When i spray them with WD40 it solves the noise problem for a few days and then the squeaking returned.
Can anyone recommend a type of lubricant that will last much longer.
techman41973 is offline   Reply With Quote
Old 03-17-2011, 04:33 AM   #2
just a tool guy
mickey cassiba's Avatar
Two come to mind...the first is a little messy, spray type grease that can be injected with a straw much like WD-40. Misty Spray shot if memory serves. The second is dry graphite...not as long lasting, but a lot neater. Hope I helped,
Mick
mickey cassiba is offline   Reply With Quote
Old 03-17-2011, 07:24 AM   #3
the Musigician
DangerMouse's Avatar
3in1 oil will do better than wd-40.
DM
Old 03-17-2011, 07:25 AM   #4
WD 40 is mainly to keep out moisture, not that good as a lubricant. Try what he suggested, and teflon or silicone based lubricants. But don't get the silicone on anything that gets painted, paint will not stick after that.
Old 03-17-2011, 01:27 PM   #5
Concrete & Masonry
Rewards Points: 470
Here's what I rely on for light lube and rust protection now:
http://www.fluid-film.com/
WARNING: Once you start using this stuff, you'll become addicted to it..............
jomama45 is offline   Reply With Quote
Old 03-17-2011, 05:18 PM   #6
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
On all the upstairs door hinges in my last house, I used Finish Line teflon dry-lube (spray can) meant to be used for bike-chains. The slightest breeze would cause every door upstairs to slam closed. Never one squeak after that though.
http://www.finishlineusa.com/product...-plus-lube.htm
hyunelan2 is offline   Reply With Quote
Old 03-22-2011, 09:17 AM   #7
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
White lithium grease.
CoconutPete is offline   Reply With Quote
Old 03-22-2011, 09:38 AM   #8
Rewards Points: 558
You can use a Teflon spray which is a multi purpose powder lubricant that is non-staining and non-oily and will not collect dirt and dust. It is chemically inert and is a fast drying dry film lubricant which can solve many friction problems you can buy it anywhere.
epson is offline   Reply With Quote
Old 03-22-2011, 09:50 AM   #9
WD40 is Water Displacement 40 like said before, not a lubricant. Be careful with graphite and your clothing, can be tough to get out. Some kind of penetrating oil should do the trick.
screwy is offline   Reply With Quote
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 01:44 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 08:47 PM
Spring Hinges jb198606 General DIY Discussions 3 02-06-2006 09:40 PM
