Squeaky Metal Floor Joist Braces - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 01:02 PM   #1
Pa
squeaky metal floor joist braces
A builder used stamped sheet metal braces between the floor joists. The braces are set in pairs so they cross like an "X".
Problem: some of the braces touch where they cross, producing the most annoying metallic squeak I have ever heard!
Any ideas on how to fix this besides ripping out the floor (or ceiling below)?
Thanks!
Aaron E
aaron emmons is offline   Reply With Quote
Old 02-09-2010, 05:47 AM   #2
Are you sure it is not plywood joints squeaking???
Old 02-09-2010, 06:17 AM   #3
Pa
Yes, I'm sure it's not the plywood. Some of these are exposed under the first floor, which you can see from the basement, and they do the same thing. It's a terrible metal-on-metal squeak.
Old 02-09-2010, 07:07 AM   #4
thats a stupid install. need to remove ceiling or floor , remove nail or screw ,separate dont just pry them apart ,refasten
The older I get the better I was
Old 02-09-2010, 08:10 AM   #5
Pa
Ok, I'll present the idea of removing a strip down the middle of the ceiling to access and re-fasten the braces. That sounds like the least invasive solution to this problem. Thanks!
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 09:32 PM
buying metal cross braces Lturgeon Building & Construction 8 09-01-2009 03:55 PM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 10:31 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
