Square Recessed Screw Head Question - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 09:32 AM   #16
jschaben
Rewards Points: 502
Originally Posted by Startingover View Post
I'll try to measure the sq hole before I go to H.D.
thanks.
You said it's "really tiny", go with a #1. Not sure if they have a #0 but they may.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-13-2012, 09:51 AM   #17
Rewards Points: 1,452
They're much harder to strip. I can't think of any reason to use philips head screws over these.
mikegp is offline   Reply With Quote
Old 06-13-2012, 09:55 AM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
They do....I have some.....it's the screws without a hole.....
ddawg16 is online now   Reply With Quote
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
mae-ling (06-17-2012), Willie T (06-13-2012)
Old 06-13-2012, 12:21 PM   #19
joed's Avatar
Rewards Points: 12,416
Roberston drive come in different sizes most often defined by colours. Starting from the smallest they go yellow, green, red, black. Red is the most common, black for the larger screws (usually #12 and up) and green for smaller sizes like #6. A properly fitting Roberston screw will stay on the screw driver even when pointed down.
The Following 2 Users Say Thank You to joed For This Useful Post:
mae-ling (06-17-2012), Startingover (06-14-2012)
Old 06-17-2012, 02:08 AM   #20
Rewards Points: 372
For the life of me I can't figure out why some screws have a recessed square. What is the name of the screwdriver I need so I don't sound like a complete moron at the hardware store? I have several flat head and several phillips but not this kind.
Willy knows of that which he speaks.
The square drive is much better than slotted or philliips heads. There are 4 sizes, 1 is the smallest, ranging to 3 or 4. A # 2 is the most popular. Cheap screws are an oxymoron.
The best place to get bits is http://www.mcfeelys.com/
This video explains how the screws are made. Don't worry, the narrartor speaks English, not Canadian.
http://blogs.howstuffworks.com/2010/...rews-are-made/
fireguy is offline   Reply With Quote
Old 06-17-2012, 09:45 AM   #21
jschaben
Rewards Points: 502
http://en.wikipedia.org/wiki/List_of_screw_drives
Hmmm, under Robertson they list a #0 and a #00.
John Schaben
Old 06-17-2012, 11:01 AM   #22
Rewards Points: 372
You are right, I have not seen #0 and #00 or the larger sizes. I first saw the Robertson screws when I worked at Champion Motor Homes. The #1 screws were used to hold on some of the trim. Electicians use Robertson screws on EMT fittings.
Old 06-17-2012, 11:58 AM   #23
JOATMON
ddawg16's Avatar
With my eyesite, there is no hole.....
Old 06-17-2012, 01:19 PM   #24
jschaben
Rewards Points: 502
http://www.lenscrafters.com/
John Schaben
The Following User Says Thank You to jschaben For This Useful Post:
Old 06-17-2012, 04:27 PM   #25
Rewards Points: 2,212
Never seen a #00 in real life
mae-ling is offline   Reply With Quote
Old 06-17-2012, 06:16 PM   #26
dogris's Avatar
How about the Authur-head screw?
http://arthureugenespooner.blogspot....rewdriver.html
dogris is offline   Reply With Quote
Removing a screw with no head yummy mummy Carpentry 19 10-18-2011 08:44 AM
Distance Between Fire Sprinkler Head & Recessed Light MartinD Electrical 2 09-26-2010 02:58 PM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 09:25 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Confused.....Halo H7ICT Recessed Lighting Question tigerbalm2424 General DIY Discussions 5 01-09-2008 07:21 AM
