Square Feet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 12:56 PM   #1
Rewards Points: 150
Square Feet
I am purchasing some bagged firewood, there are 50 bags on a pallett. I want to cover 10 palletts. How big of a tarp will I need to cover the whole area so the tarp is covering top to bottom? thanks.
econdave is offline   Reply With Quote
Old 01-07-2011, 01:00 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,... So what size are the pallets,..??
What configuration will the pallets be aligned,..??
How tall are the stacks,..??
Is multiplication to much for ya,..??
I'm no mathimagician, but I do know the answer can't be found without some numbers to start with.....
Old 01-07-2011, 01:50 PM   #3
cocobolo's Avatar
Rewards Points: 6,098
250 square feet.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 01-07-2011, 01:52 PM   #4
Experienced
Jackofall1's Avatar
Well I will see your 250 and raise you 250.
Isn't that how it works? 50bags x 10 pallets. Duh.....
Old 01-07-2011, 01:58 PM   #5
Rewards Points: 150
square feet
pallets are 4x4 wood is 5 feet high pallets will be side by side
Old 01-07-2011, 01:58 PM   #6
cocobolo's Avatar
Sounds good to me...
Old 01-07-2011, 02:03 PM   #7
cocobolo's Avatar
You win, more like closer to 500 sq. ft.
Old 01-07-2011, 02:13 PM   #8
10 pallets = 40' long, then 5' up & then 5' down the other side
So that is a 50' long tarp
Then 5' up one side, 4' across, 5' down the other side
That's 14'
14x50 = 700 sq ft
A lot of the pallets I find are not an exact 4x4
Old 01-07-2011, 02:20 PM   #9
trick question.... the wood is bagged. No tarp needed....
ferris13 is offline   Reply With Quote
Old 01-07-2011, 02:23 PM   #10
Experienced
Jackofall1's Avatar
Ding...Ding....Ding you win the magic prize. See OP for contest rules and regulations.
Old 01-07-2011, 02:25 PM   #11
Rewards Points: 150
no trick question wood is bagged in onion bags for air flow
pallets will be 20 feet long 8 feet wide and 5 feet high I need total coverage figured in to a tarp ex. 20x30 or 30x50 etc.
Old 01-07-2011, 02:35 PM   #12
Really ? This is simple math
20' long...5' up & down = 30'
8' wide + 5' up & down = 18'
Anything bigger then 18x30
And that's down to 540 sq ft
Much better 2x up the row
Old 01-07-2011, 04:32 PM   #13
concretemasonry's Avatar
Rewards Points: 2,626
You need a little extra to run the the tarps out at the bottom for weight to keep them in place or use stakes to prevent the wind from lifting the tarps and aerate the carefully bagged fire wood.
Seriously, usually, you only need to cover the top and a little down the side so you eliminate the rain/snow problem and still allow ventilation and prevent rot.
Dick
concretemasonry is online now   Reply With Quote
Old 01-07-2011, 05:04 PM   #14
Bondo's Avatar
Ayuh,... Exactly,...
Or,...
Stack it Bark side Up, 'n you don't even need a tarp....
Old 01-07-2011, 05:32 PM   #15
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
Square feet would make it hard to find shoes that fit.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
asbestos Donnie L. Safety 57 11-27-2012 02:57 PM
Lets Play The "How Much Stain Will I Need?" Game! Bgm94 Painting 5 02-11-2011 09:53 AM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 09:29 PM
