Spray Foam Degradation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 01:43 PM   #1
Spray foam degradation
Is anyone aware of any studies regarding the expected life of expanding foam insulation? I was doing some renovation and found some rigid insulation that just crumbled apart when you touched it.
Timberwright is offline   Reply With Quote
Old 01-25-2009, 03:39 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i think over time the foams do lose a little r value.Ithink you found some old urea formaldehyde foam that does degrade over time
Tom Struble is offline   Reply With Quote
Old 01-27-2009, 02:51 AM   #3
i've had some insulation foam crumble apart after 2 years.
@home is offline   Reply With Quote
Old 01-27-2009, 08:45 AM   #4
Registered User
Termite's Avatar
The modern spray-in foams such as Icynene are long-term products that will last the lifetime of the home. These foams are not as rigid as DowBoard, etc...They have a little flex to them. I would not anticipate any degradation or any significant loss in R-value. Even if some R-value was lost, you're still way ahead of any other insulation on the market.
Old 01-27-2009, 02:35 PM   #5
Rewards Points: 392
There's a difference between spray foam and rigid insulation. I've come across some board insulation that crumbled too; I'll bet it even would crumble when it was installed new.
rustyjames is offline   Reply With Quote
Old 01-28-2009, 02:40 PM   #6
Rewards Points: 176
I used some DAP sprayfoam to seal a gap on the house, running along the bottom of the siding. It crumbled into powder a few weeks later when I tried to pull a piece of it out. But, it was very cold outside when I sprayed it and I'm assuming that's why it crumbled. It did expand and set-up though.
One thing about the spray foam that I didn't see on the can is that you can't use it on surfaces that will reach 240 degrees F. I thought the Great Stuff Fire-Blocker would be alright to fill a penetration in the attic floor between the hot water heater exhaust pipe and the wood/drywall around it. I thought if it's a fire blocker, it can handle high heat. I used it for that and a few days later found out it can't be used on hot surfaces either. I was up there last night cutting it away from that hot pipe, the foam has been around the pipe for about 3 weeks or so. The foam that was directly in contact with the pipe was melted and looked like orange hard-candy. I had to use a metal putty knife to pry it off. The foam about 1/2" out from the pipe looked normal.
gma2rjc is offline   Reply With Quote
Old 01-28-2009, 10:41 PM   #7
the spray foam in a can is not supposed to be exposed to UV, that will degrade it fairly quick
Spray foam insulation troyce1 Insulation 12 12-14-2014 07:30 AM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 05:04 PM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 03:48 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 08:12 PM
Spray foam simonb Building & Construction 6 11-30-2007 08:11 AM
