Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-10-2009, 10:05 AM   #1
Home Remodeler Wannabe
Scotsman's Avatar
Sponging Wet sheetrock mud? Good Idea or No?
I am ok at hanging sheetrock, BUT finishing, not so good! For some reason I tend to overmud seems and can NEVER EVER get them TRULY smooth. Soon as I paint BAM! I have been told that if I take a DAMP NOT WET sponge and go over the joint it will smooth it out ALMOST to the point of not needing to sand at all? Is this true? Is good? (if it works it would be stupendous) Or is it bad. Can anyone expand a little on the technique? Other suggestions are GREATLY APPRECIATED!!!!
Thank You
Scotsman is offline   Reply With Quote
Old 11-10-2009, 11:54 AM   #2
Old School
Willie T's Avatar
Actually a spray bottle of water and a 12" knife work better for me if I'm getting real picky about a joint.
Willie T
Willie T is online now   Reply With Quote
Old 11-10-2009, 12:27 PM   #3
Moderator
I first do as Willie said, then to invisible blend the repair to the old painted finish, I use this with water: http://www.homedepot.com/webapp/wcs/...THDStoreFinder
Be careful! The new material comes off very easily and quickly.
Be safe, Gary
Clothes taking longer to dry?
Old 11-10-2009, 12:57 PM   #4
Old School
Willie T's Avatar
The kind of tool (flat and hard) that Gary mentioned is usually best for drywall. Sponges and hand sanding (no backer) will invariably leave streaks and grooves until you have enough skill and practice to avoid leaving them.
Willie T
Old 11-10-2009, 02:54 PM   #5
You need to be careful using a sponge on raw sheetrock. If you get the paper wet, it will raise paper fibers all over the exposed areas. You would then need to sand down the surface or the paint will look like hell.
Ron
Old 11-10-2009, 03:14 PM   #6
We pick these?
In my limited drywall finishing experience... I was trying to hit the joints with the sponge too soon. I used mostly setting compound so I thought I would have to smooth it while still wet, but that wasn't the case, I found. My finishing looks best under a heavy knockdown...
NailedIt is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 73 04-07-2013 08:35 PM
Water damage to ceiling sheetrock Go4EVA! General Discussion 8 08-29-2009 09:25 AM
Creating a hole in the wall to run wires, a good idea? RyanD General Discussion 6 05-19-2009 04:30 PM
Good Idea or Not? PearlWhiteGT Interior Decorating 16 05-15-2009 05:38 PM
Gluing Sheetrock to exterior wall? BengalfanMT Building & Construction 11 04-16-2009 10:22 PM
