Splitting Heat In Multi Unit House - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 06:45 AM   #16
Rewards Points: 1,512
You can split electricity starting with the next lease renewal for each apartment if you install separate meters and panels. A few cities will allow you to split electricity if you kept the existing meter but added submeters and subpanels for each apartment.
Similarly, splitting the heat normally requires separate furnaces. In a few cities you can install timers and meters on forced hot water furnaces to split the cost of the heat in proportion to the readings on the respective timers and meters.
It would be okay to install a furnace of a different kind for example if two units shared a forced hot air furnace, you could install forced hot water heat in one unit and keep the existing furnace for the other. For this to succeed you would need to be able to lower the blower speed for the forced air furnace now outputting to fewer ducts.
In one condominium complex where I owned a unit we could put meters on the FHW heat but residents complained and nitpicked about upstairs apartments being inherently warmer and the meter conversion was nixed.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat Pump Outside Unit Will Not Run savaytse66 HVAC 1 08-14-2011 07:44 AM
House Heat Loss Kirsch Building & Construction 6 12-26-2010 10:58 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Best way to heat old house brian12345 HVAC 8 09-23-2008 02:32 PM
