Splicing Cables - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-19-2007, 04:28 AM   #1
Splicing cables
I have a safety cable on a lawn mower that has been cut. I've been trying to reattach it without any success. I've tried almost all the cable splicing gadgets they have at HD. The cable is 1/16th thick. I was wondering if it would hold if I used my MIG welder? Any suggestions?
sluggermike is offline   Reply With Quote
Old 09-19-2007, 08:15 AM   #2
RippySkippy's Avatar
Is it something that may be easier/better to replace than fix? A couple of options for wire rope: clamps and/or sleeves
RippySkippy is offline   Reply With Quote
Old 09-19-2007, 02:17 PM   #3
I'm having a problem finding the cable, otherwise, I would have replaced it. I've tried sleeves and clamps. Thanks
Old 09-20-2007, 05:53 AM   #4
guess then you don't have much to loose then...weld away!
Old 09-20-2007, 11:39 AM   #5
Rewards Points: 264
It won't weld.
Go to a bicycle shop and pick up a universal cable.
Jeekinz is offline   Reply With Quote
Old 09-20-2007, 01:39 PM   #6
Thanks for all your help. I was able to splice it with sleeves and it works fine.
Old 09-23-2007, 02:57 PM   #7
Rewards Points: 6,652
Check with your mower shop, due to they should either have the cable in stock, or be able to order one for you.
Cables for fiber-optic TV mt232 Home Theater 3 04-16-2007 06:27 PM
How to mount cables on masonry wall without conduits? dave.murphy Electrical 5 01-24-2007 04:19 PM
