-   -   Splicing cables (http://www.diychatroom.com/f2/splicing-cables-11665/)
sluggermike 09-19-2007 04:28 AM
Splicing cables
I have a safety cable on a lawn mower that has been cut. I've been trying to reattach it without any success. I've tried almost all the cable splicing gadgets they have at HD. The cable is 1/16th thick. I was wondering if it would hold if I used my MIG welder? Any suggestions?
RippySkippy 09-19-2007 08:15 AM
Is it something that may be easier/better to replace than fix? A couple of options for wire rope: clamps and/or sleeves
sluggermike 09-19-2007 02:17 PM
I'm having a problem finding the cable, otherwise, I would have replaced it. I've tried sleeves and clamps. Thanks
RippySkippy 09-20-2007 05:53 AM
guess then you don't have much to loose then...weld away!
Jeekinz 09-20-2007 11:39 AM
It won't weld.
Go to a bicycle shop and pick up a universal cable.
sluggermike 09-20-2007 01:39 PM
Thanks for all your help. I was able to splice it with sleeves and it works fine.
gregzoll 09-23-2007 02:57 PM
Check with your mower shop, due to they should either have the cable in stock, or be able to order one for you.
