Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-07-2009, 09:24 PM   #1
Default Spilled Cooking Oil
I recently spilled cooking oil on my ceramic tile kitchen floor. I have tried everything I can think of to remove it but it still feels as though there is a residue on the tile. I'm looking for ideas to clean it...thanks!!
kaitiesgramma is offline   Reply With Quote
Old 07-08-2009, 12:49 AM   #2
Kap
Mowing my life away.
Hot water?
Kap is offline   Reply With Quote
Old 07-08-2009, 12:51 AM   #3
Kap
Castrol Super clean. But test it an an inconspicuous area first.
Old 07-08-2009, 02:05 AM   #4
Default Hot Water
Tried hot water....no luck. Even added a degreaser. Will try the Castrol
Old 07-08-2009, 04:37 AM   #5
Kap
Castrol is a degreaser. But a tough one. FYI, it can strip paint at it's full strength.
Old 07-08-2009, 07:28 AM   #6
Default Castrol
Thanks, I will definitely look into it!
Old 07-08-2009, 11:07 AM   #7
Learning by Doing
Leah Frances's Avatar
TSP or TSP substitute. Available at big box stores, hardware stores, or paint stores.
Also, most people have a can of oven cleaner around... test in a small area before you use it. USE IT ONLY a SMALL AMOUNT AT A TIME IN A HIGHLY VENTILATED AREA.
Good luck. Veggie oil is a biotch.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-08-2009, 12:39 PM   #8
Default Tsp
Thanks Leah...you are right, this has been a nightmare to clean up!
Love the thought for the day at the bottom of your note!
Old 07-10-2009, 11:15 PM   #9
Kap
How about rubbing alcohol? It can break down some oils. Might be worth a shot.
Old 07-11-2009, 12:57 AM   #10
Tileguy
Cooking oil should in no way damage any ceramic tile. The grout is a different story. For the grout use a poultice to remove the oil. You can buy a ready-made poultice product at Home Depot or you can make your own. I would suggest the Home Depot product first.
The last thing you want to put on the tile is any caustic such as an oven cleaner. TSP (as suggested) or Oxy Clean should clean the tile surface easily.
More On This Topic
Using Mosaic Tile Grout
Using Mosaic Tile Grout by Expert Village
You'll find grout at any hardware store. You'll find sanded and non-sanded grout. Sanded grout is good for almost every mosaic project. The theory is, as long as your grout joints are more than a quarter inch apart, then you'll want to use sanded grout... Read More »
A grouting float is a flat, rectangular piece of metal with a handle on the top that is used to apply grout to a tiled floor. The float is used during one of the final stages of the tiling process and is relatively simple to use. Read More »
I’m Lee; I have a degree in architecture and about ten year experience in the construction field, and we’ve just finished, yesterday, grouting our designer countertop. I’ve already wiped this one down. You just want to take a sponge and... Read More »
Today we’re going to be re-grouting the tile around the window in the bathtub. Once your grout has set out for about five to eight minutes, you get yourself a grout trowel, which is just spongy so you can apply the grout. And you just scoop some... Read More »
Mosaic Tile Safety
Mosaic Tile Safety by Expert Village
Today I'm going to teach you how to make a very simple and basic tile mosaic mirror for your home. We're going to take one nice small wooden mirror and some beautiful different kind of tiles for indoor use. I'm going to teach you how to break the tiles... Read More »
Spikked Cooking Oil kaitiesgramma General Discussion 2 07-09-2009 02:18 PM
New cooking top on old 200V plug sahucd Electrical 3 08-24-2008 08:35 AM
Converting to Propane for cooking fburke Plumbing 0 08-05-2008 05:29 AM
Repair cracked glass cooking hob Anto318 General Discussion 2 01-03-2008 02:24 PM
Spilled Candle Wax on Laminate Floor chrisdeanachris Flooring 5 10-17-2007 03:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
