Spigot Tightening Upside Down? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 06:39 PM   #1
Rewards Points: 358
Spigot tightening upside down?
I went to replace a leaking spigot and when I did so it then came to a full tight when it was upside down?? How do I fix this, if I loosen it so the spout is facing down, it then leaks out of the threads, if I fully tighten it the spout is facing up.. I really would rather not have it like this, is there a way to make it work?
cbzdel is offline   Reply With Quote
Old 08-08-2011, 06:52 PM   #2
Tell your friends its a drinking fountain and leave it pointing up!
Seriously, remove the spigot and wrap the threads with teflon tape and then screw it in until it faces down. Of course, now your friends will have to drink the beer from a mug!
Old 08-08-2011, 07:42 PM   #3
Rewards Points: 358
first wrapped it (3) times with tape, the second time I wrapped it (6) times, it just keeps leaking.. Maybe there threads flawed in some way?
Plus when its pointing straight down, its still kinda loose I can turn it by hand..
Old 08-08-2011, 08:03 PM   #4
Experienced
Jackofall1's Avatar
How tight have you made this hose bib, you sure you couldn't get another 1/2 turn out of it?
There is a sealant by locktite called Locktite 565 which will help your situation, unfortunately its like $25 for a tube, I am not sure if its sold in smaller quantities, but the stuff works well.
It will act as both a lubricant to let the threads turn without gauling as well as seal.
Mark
Old 08-08-2011, 08:34 PM   #5
Learning by Doing
Leah Frances's Avatar
You could also slap an o-ring on it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-09-2011, 07:19 AM   #6
Rewards Points: 5,336
Go inside and remove the bib connection at the nearest joint.
Run copper out to the bib with a coupling in between..
Connect the hose bib to the copper and properly orientate it.
Attach the bib to the house.
Go inside and solder the coupling.
Turn on the water.
Ron
B. Franklin 1759
Hot Water Heater Spigot Leak ellisje007 Plumbing 10 05-24-2016 03:10 PM
Outside spigot question... carpenter981 Plumbing 31 10-06-2011 09:28 PM
Freeze Proof garden spigot replacement DK75 Plumbing 8 04-15-2010 07:13 AM
Roman Tub Spigot Problems - Phoenix Corp? bkw Plumbing 1 10-17-2008 03:21 PM
Installing a Hot / Cold Water Spigot dc2295 Plumbing 1 02-25-2008 05:10 PM
