-   -   Special Door Lock for gates? (http://www.diychatroom.com/f2/special-door-lock-gates-118522/)
acerunner 09-27-2011 07:23 PM
I want to replace a lock for a wrought iron gate.
The bolt mechanism is that of a standard door, triangular wedge that retracts when u close the door. But there are no handles, rather it has faces more like a deadbolt. Key-only on the outside, and a turn lever on the inside.
I want to replace as is since I like the convenience of being able to close the door behind me when i leave instead of having to lock the deadbolt.
I am having trouble finding a replacement for this at the big box stores. In fact, I don't even know what this type of lock is appropriately called. Big box stores only has knobs (hallway/bath, bedrm, keyed entry) or deadbolt. None of which can mix the bolt mechanism of the knob-type locks, with the "handles" of a deadbolt.
Ron6519 09-27-2011 07:36 PM
Post a photo of what you have and some info on the lock.
Is it a 2 3/8" setback from the edge?
Is the hole in the door 1 1/2" or 2 1/8" or something else?
Mr Chips 09-27-2011 07:52 PM
If you want something that looks like what you have now, but automatically always locks behind you, and has a turn knob on the inside, do a google search for a " gate nightlatch ". I believe that might be what you are after. It's basically a single cylinder deadbolt that utilizes an entry style backset
EDIT:
http://absupply.net/images/GL220.jpg
i just looked and found this by googling the term above http://absupply.net/gate-cgl220-latc...linder-33.aspx This sounds like what you are after
epson 09-27-2011 08:15 PM
I believe he is referring to a mortise lock like this
http://www.homedepot.com/catalog/pro...697407_300.jpg
We use this type when we fabricate a steel gate or door. The lock would be incased in a steel tube that we fabricate for the lock to fit or a steel box welded to gate/door.
acerunner 09-27-2011 09:42 PM
EDIT:
Yes, that's exactly what I have. Gate night latch. thanks
