Spacing Of Furring Strips In A Shower - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 10:07 PM   #1
Rewards Points: 1,606
Spacing of furring strips in a shower
I have a shower area that is 5' wide, 7' long. Two sides of it are concrete block walls which I am attaching 1x3 PT furring strips. The other side is interior wood studded wall.
Is there a certain spacing to place those vertical strips to make it easier to attach the durock or hardibacker boards? For the 5' wide area I was going to attach 4 strips spaced 15" apart but then I though this is probably not going to result in having the butt end of two durock panels on a strip. What is the best spacing to use?
How do they cut the durock panels? Does it require a concrete saw or do you score it with a knife and snap like sheetrock?
miamicuse is online now   Reply With Quote
Old 01-17-2013, 10:19 PM   #2
Rewards Points: 2,238
Just make sure the joints on the cement board are going to land on the furring strips.
You can use a knife to score the panels -
we use a saw (wear a dust-mask!!!!)
Use Cement-board screws - not D-Wall screws - to fasten the panels.
rossfingal is offline   Reply With Quote
Old 01-17-2013, 10:29 PM   #3
Rewards Points: 13,296
Every 16", good luck trying to just score a 1/2 thick panel and snap it.
I use a carbide blade or a diamond blade on a ciruler saw.
Wear a dust mask and work out side there's going to be dust everywhere.
Old 01-17-2013, 10:56 PM   #4
If I go every 16", in other words:
|---16"---|-----28"-----|---16"---|
I will end up with a space of 28" in the middle. I can't put one right in the middle because I have a thermostatic valve, a diverter valve, and a shower outlet all along that vertical line.
If I put one to either side of the middle, then I will end up with:
|---16"---|--9"--[10"]--9"---|---16"---|
Old 01-17-2013, 11:33 PM   #5
That would be fine as long as there all less then 16".
Old 01-18-2013, 05:52 AM   #6
DIY staff
Rewards Points: 7,174
I see a couple of problems on the horizon---Your furring strips are only 3/4" thick---then you hit concrete---if you can't use thicker furring strips---be careful with your screws---you may bottom out on the concrete and pull the strips loose---
As to cutting durrock?
A sharp knife will let you score and snap like drywall.
For dust free sawing--I use a 4" diamond saw and slap a wet sponge against the blade---no dust.
miamicuse (01-20-2013)
Old 01-18-2013, 07:39 AM   #7
Rewards Points: 3,130
What a great idea. Wish I'd thought of it.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (01-18-2013)
Old 01-18-2013, 08:49 AM   #8
Can you elaborate "slap a wet sponge against the blade"? You mean wipe down the blade with a wet sponge? Would like to know exactly how to do that. Thanks.
Old 01-18-2013, 05:07 PM   #9
DIY staff
This is the type of saw that I use (Harbor Freight model)
The blade spins fairly slow---when cutting I dunk a sponge into a bucket of water and press it against the blade and start cutting---squeeze the sponge as you go and dust is gone---
one quick wipe of the board removes and slurry---been doing it that way since 1998---
Saw is on sale for about $39---I replaced the 1998 one a year ago--the cord was getting ratty--
Old 01-18-2013, 06:30 PM   #10
Rewards Points: 2,210
I use a spray bottle and water
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Old 01-20-2013, 12:07 PM   #11
Yes I thought about that. I guess I am going have to use short cement board screws.
They sell 1-1/4" long ones.
So the 1x strips are 3/4" thick, and the board is 1/2" adding to 1-1/4". If there are any thickness variations or I drive the screw too deeply I might hit concrete before the screws bottoms.
I can't use thicker strips as the existing strips are all the same thickness. What I might have to do is for those shower walls that are against 1x strips on concrete blocks I use 5/8" cement boards to give a little extra thickness. The interior walls are not a problem since those are 2x4 studs.
Old 01-20-2013, 12:10 PM   #12
Thanks. I might have to try that. Are you concerned about the wet sponge carrying water into the saw and the parts inside the housing?
Old 01-20-2013, 01:20 PM   #13
DIY staff
The thing is designed for use with a water hose attachment---totally useless---I never had an issue--
Old 01-20-2013, 09:02 PM   #14
OK, what brand model saw do you use? I might get one like that to cut my boards. Thanks.
Old 01-20-2013, 11:20 PM   #15
Another related question.
If you have to make a special cut for a non-circular hole, such as when a shower valve, where I need to cut a six sided shape to include not only the valve dial but access to the stop valves on either side.
How would you cut a shape like this? I have several to cut.
For circular holes I have diamond coated hole saw bits.
For odd shapes like this what is the best way?
Use an oscillating tool like a JobMax with a carbide blade?
Use a rotozip to craft it out?
Use a drill with masonry bits to drill holes every 1/2" then bang it out with a hammer?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Studs vs Furring Strips In the Basement brockmiera Building & Construction 9 10-12-2012 11:11 AM
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 09:30 AM
Grout line spacing shower niche over shelf Wapmiasomey Tiling, ceramics, marble 0 07-16-2012 09:26 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
