Spaces Between Loft(ceiling Joists) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 06:26 AM   #1
Post
Spaces between loft(ceiling joists)
Dear All
Maybe a simple question to you tradesmen, can anyone tell me the required and/or average distance between loft joists? also can anyone recommend what i use in the loft so as i dont fall between the joists?
All advice very much appriacted.
Cheers
Brijja is offline   Reply With Quote
Old 07-27-2009, 09:24 AM   #2
Registered User
Termite's Avatar
Definitely need more info. Is the loft existing? Is it something you're thinking of building? Is it currently an attic (and if so what is the size and span of the ceiling joists)?
Framing members are spaced 12" on center, 16" oc, 19.2" oc and 24" oc...Totally depends on a number of factors.
Pictures are worth a thousand words!
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Opening Up Stairwell Wall jeffmn Remodeling 15 12-31-2008 05:21 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
