To Space Between Slats In Privacy Fence? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 09:18 PM   #1
To space between slats in privacy fence?
So I'm putting up a new privacy fence. Gonna go with installing individual slats as opposed to pre-bought panels. Have had "many" tips from good friends who have done the same and some who are actually semi-pro at it. Up until today, I was told to nail/screw each slat as flush as possible up against the adjacent slat as the wood would shrink over time and I WILL have spaces between them eventually. (Also advised to plumb bob the slats every few to keep them true vertical).
Well today while buying a few supplies at Big Box Store, the local pro told me to actually space my slats about the width of a #2 screwdriver apart because the cedar slats will expand when they get wet and if they are attached flush, this will cause them to warp.
So??????????????????
(also, please advise me if I should post this on a "better" subforum; I couldn't really tell from cruisin' around here where to post this)
duck whisperer is offline   Reply With Quote
Old 04-03-2010, 10:13 PM   #2
remodeling pro
Follow your friend's advice on this and install the boards tightly. They contain enough moisture so that when they dry, they will indeed have space between them, anywhere from 1/8" to 1/4", which will be enough to allow for expansion when they get wet again.
A decent 4' level will work ok for plumb; if you have, or can borrow a 6'er, so much the better.
troubleseeker is offline   Reply With Quote
Old 04-03-2010, 10:23 PM   #3
A lot depends on the moisture content when the boards are installed. I did a similar job a few years ago and the boards expanded and actually broke the heads off some of the screws. I would at least use a 16d nail to space the boards, after all it's outside and will be wet many times. Why take the chance for a little more privacy?
Giles is offline   Reply With Quote
Old 04-03-2010, 10:40 PM   #4
jlhaslip's Avatar
Rewards Points: 2,096
Spaces. At least the width of a framing spike.
The spaces also allow the fence to pass wind through it better than when the boards are tight together.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
shadowbox fence, privacy? johnnyboy Building & Construction 1 06-05-2009 05:50 AM
A few questions about building a wooden privacy fence in Florida Tineras Building & Construction 4 03-22-2009 01:38 PM
Privacy Fence on one side? caseydm Landscaping & Lawn Care 9 10-28-2008 10:13 AM
Chain Link Fence Privacy? the question General DIY Discussions 2 06-15-2008 10:08 AM
Privacy Fence Gate Dallas Carpentry 8 11-20-2007 08:12 PM
