Solution for Bad Advice - Latex on Bookcase
4K views 8 replies 7 participants last post by  mark942
Guys,
I just jointed the forum. It looks great!
I received some bad advice at Ace Hardware. I told them I was painting birch libraray cabinets and asked for the best paint. They gave me Kilz oil based primer and BM Latex paint.
After about 1 coat of the primer and 2 coats of the latex it was not turning out like I wanted and it was very sticky.
Then I started snooping on the web and was informed that you should not use latex on cabinests because it is sticky and soft.
So I am looking for a solution.
1. I could strip or sand down the paint and redo. If so what kind of stripper for latex, what kind of primer and paint should I use to get a great result.
2. Can I rough up the existing paint and reprime and repaint. If so what primer and type of paint can I use. What grit sandpaper is best?
3. Any other solution that would work well.
I am a newbie and probably should have know the latex was wrong. I take repsonsibiltiy for it. I just need some great advice.
Thank you in advance.
Jim
I don't like latex paints for the way they look when done. I have had the problem you mention on occasion. It usually was because I did not allow sufficient drying time, and sometimes due to humid weather. At this point, I see a stripper in your future, then follow directions. or use oil based paint, takes even longer to dry, but looks so much better.
#4 · (Edited)
I like chrsin have used Latex with great results. I also like Just Bill have used oil with great results. Like Just Bill said Humidity/Heat, ect can effect the paint. A citrus type stripper would be your next move, while the paint has not cured to it`s fullest, it should be a pretty straight forward job. Apply stripper,Scrape off, then use 100 grit paper down to 220 grit until you get a baby bottom smooth finish. A heat gun might be a idea as apposed to a stripper. Oil primer is a must here. Top coat with latex or oil, both have great results,eggshell or a semi gloss finish would be my thought. But there are those who will say OIL is the only way to go and then there will be those who say LATEX is the only way to go. To each their own I say. Be sure to read and follow all directions as already posted.......................Go to your local paint company Benjamin Moore, Not Ace, and ask the rep for suggestions...............Good Luck to you................................:thumbsup:
You could wait until the paint has cured and see if a sanding it all out as apposed to stripping will work. But if your like me and have to have it done ASAP do as suggested.
#5 ·
A few years ago, I had a beautiful hardrock maple end table that I wanted to refinish. I went to Ace Hardware and bought a high gloss polyeurethane stain and sealer and their clear finish.
Applied per directions and a week later the clear coat was still wet to the touch:furious:
I found out that some of Ace Hardware finishes are manufactured by Ace, and this was one.
I called the 800 number and spoke to a reperesentative. He stated that you could not finish Hardrock Maple:censored:--It would not dry:censored:
I hung the phone up and went to SW and their product worked beautiful, after I completely stripped the defective Ace finish.
Ace offered NO Assistance--not even a refund.:(
#6 ·
before stripping and redoing I would give it a bit more time. If the paint looks good and is just a little sticky do this. Let it cure for a week or so. Then top coat it with some ultra clear water based polyurethane.
Something like this
http://www.minwax.com/products/wate...ve_finishes/polycrylic_protective_finish.html
The poly will give you that hard clear top-coat you want. The paint gives the color/look you want. The spray will give a nice, smooth, finish but may be too expensive for a large project.
Try it on a sample, scrap board, or inconspicuous area first to make sure you like the look.
