Solar Water Heater - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 09:47 AM   #1
Rewards Points: 154
Solar Water Heater
This unit was installed on my house in 1985. There are no moving parts. Water pressure pushes water up through the pipes/tubes and back down into the hot water heater.
About 10-12 years ago a tube broke and sprang a leak in one of panels and I shut it off. I do remember saving quite a bit on my energy bill. I am now thinking of repairing it or at least by passing the panel with the broken tube.
Has anyone ever worked on one of these? I don't see this type installed anymore. Is this old technology, not as efficient as other systems? Some of the newer systems involve separate plumbing and fluid that is pumped through the water heater.
ovahimba is offline   Reply With Quote
Old 08-03-2010, 09:51 AM   #2
I have 6 panels with pipes/tubes
One heats my hot tub to 104-108
How to fix it depends upon the assembly method & pipe
2 of my panels are alum tubing, the others are copper
Screws hold the top glazing on top
So I can solder new pipe in...or install a hose/clamp to patch a leak
It is older Tech, but works just fine
Evac tube water heating is the new setup
More effic
30% tax credit thru Govt on a system thru the end of the year
Old 08-03-2010, 09:53 AM   #3
Rewards Points: 154
Lets see if the picture post
Solar Water Heater-img_3642.jpg   Solar Water Heater-img_3643.jpg   Solar Water Heater-img_2223.jpg
Old 08-08-2010, 12:19 PM   #4
The danger of using a system such as yours, is freezing!
It can only be used at times when temps are above freezing and must be properly drained to prevent the pipes from being damaged when it gets cold.
Closed systems are filled with anti-freeze and can be used year round.
Closed systems usually require a circulating pump. This costs money to operate and of course, won't work during power outages.
Old 08-10-2010, 09:39 AM   #5
Rewards Points: 154
Thanks for the replies. If its only copper pipe inside, it may not be that difficult to fix. The big issue might be getting off the corroded screws that attach the panels.
We get severe freezes here only once every few years and even then copper pipes in other locations around the house were not affected.
But its there so I might as well be using it.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Solar Hot Water Heater DangerMouse Plumbing 41 01-03-2012 05:53 AM
batch solar water heater lonzu Plumbing 0 05-09-2010 03:32 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
