So It's Really Cold Here - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 09:24 AM   #1
Question
So it's really cold here
And I need some advice from some experts.
We live in a townhouse in Northern MD. There is a wood burning fireplace in the corner of the main room of our finished basement. I would like to take it out and install a pellet stove or a wood burning stove.
I was advised to have the chimney check for "fire rating" to be sure it can stand up to the temperatures a stove would produce. Who do I call for this? Also are there any other "offices " I will need to get approval from before I attempt this?
Brrrian67 is offline   Reply With Quote
Old 02-04-2009, 09:34 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
The company you purchase the stove from should be able to send somebody out to see if the existing chimney is rated for what you want to install.
Old 02-04-2009, 09:37 AM   #3
Thanks that's what I needed, a starting point.
Old 02-04-2009, 10:05 PM   #4
buletbob's Avatar
glad to help,
Old 02-05-2009, 04:56 AM   #5
Rewards Points: 150
Check with your insurance company first!
Gary
Gary_602z is offline   Reply With Quote
Old 02-06-2009, 07:16 AM   #6
Contractor
cobracdn's Avatar
.. and your local codes.. which your local supplier should be familiar with
Cheers
cobracdn is offline   Reply With Quote
Old 02-06-2009, 10:24 AM   #7
Actually a stove is a stove so to speak
My last house they noted the wood stove
I was buying a new one & asked if they needed anything on the new stove. They said it didn't matter what stove was installed as long as they knew for insurance purposes a stove was installed
Some areas you need it inspected/permit, and the fire dept may need to see it.
Old 02-06-2009, 11:03 AM   #8
concretemasonry's Avatar
Rewards Points: 2,570
My mother installed a "Franklin stove" - completely legal and proper and her insurance company would not insure her because they "had too much liability in the area with wood burners" (like those companies avoiding hurricane country). She had to get another insurance carrier with a minor price increase for the wood burning.
One of the problems the insurers run into is infrequent, amateur fire starters operating the systems for short periods infrequently and not having them maintained. There were many people in her area that use wood for their main heat (LP back-up) and recognize how to run it and never let he chimney cool off (they all seen to use masonry chimneys and not "tin" ones) - that is why there were so many people, but the national statistics did not recognize the familiarity of the person with the system.
My mother was 70 at the time and always spent the winters in northern Wisconsin at her lake home and split her wood. Her 72 year old husband cut down the trees (birch, white oak and maple).
Dick
concretemasonry is online now   Reply With Quote
Old 02-07-2009, 07:56 AM   #9
Contractor
cobracdn's Avatar
Your proximity to the local fire department can also have an effect on insurance. If their response time to your location is over 15 minutes, you may have to pay a higher premium or worse they just won't insure you.
Cheers
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 11:50 PM
