So I Have A Slight Window Depth Problem.... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-17-2009, 12:27 AM   #1
Unhappy
So I have a slight window depth problem....
I'm sure there have been a few that have made this mistake in the past. I ordered new Pella 850 Series windows from Menards. When they were ordered, they were ordered with a 6 9/16" jamb when it should have been 4 9/16". Yea I know, kind of a crappy deal, but they are here and I need to find a way to cut these down and deal with this "small" problem. Any recomendations? I will be having one of my carpenter friends helping me install them, so i'm sure he's got an idea, but maybe someone has made this mistake in the past. Thanks for all the info in advance!!!!
scallionrm is offline   Reply With Quote
Old 03-17-2009, 06:11 AM   #2
Not sure how Pella does it. Where the extra depth is added to the window is usually on the inside of the frame, often as an extension jamb. You should be able to trim that off fairly easily.
Old 03-17-2009, 06:56 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
yea i belive you can carefully remove the extension its toe nailed with staples i belive
Tom Struble is offline   Reply With Quote
Old 03-17-2009, 08:36 AM   #4
Just took a measurement of that extension, and it measures out 2 3/4". Wont that be too much?
Old 03-17-2009, 10:44 AM   #5
i think the extension jamb for the 2x6 wall thickness is added on to the standard 2x4 wall thickness its a seperate piece no?
Old 03-17-2009, 10:47 AM   #6
Rewards Points: 5,336
The only person right now who can answer that question is you, as you're the only one standing in your house and see exactly your construction.
Ron
I don't know how you can even order pre installed extensions as the installed window will not sit the same as the current window. They're made differently. I always order extension casing and field install it.
Old 03-19-2009, 08:26 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You have to knock off the jamb extensions. Install the window and then determine what additional wood needs to be added. It is really no big deal...Please don't take offense to this, but this is really a basic and simple problem to deal with. You may want to contact a professional about installing your windows. I'd hate to see you have issues with such a large purchase due to improper installation.
...just noticed that you will have a carpenter helping you. I'm sure he should be able to handle the situation...If not, then my above advice stands.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 11:56 AM
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
Window jambs syl Carpentry 2 01-12-2008 05:01 PM
squeeze & learn..slight problem Lin Electrical 1 02-06-2004 06:46 PM
