Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-01-2009, 04:09 PM   #1
snowblower repair
I have a Toro 20 which last spring I put away after running sta-bil thru it...got it out this winter, ran once and would not start again. I replaced the spark plug and put a new carb diaphragm in it...it starts, but won't stay running....any ideas ?
carguy is offline   Reply With Quote
Old 01-01-2009, 04:51 PM   #2
snowblower repair
Is the fuel valve open?
Does it stay running with the choke on?
I had a similar problem this year and it would stay running with the choke on yet stall after turning off the choke. Turned out to be a few things. Bad spark plug, needle adjustment screw was missing, stuck float and stuck throttle. Its amazing it even started with all that wrong.
Sounds like it isnt getting enough fuel.
creamaster is offline   Reply With Quote
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
Toro SnowBlower 521 metallic sound mteach General Discussion 1 12-13-2007 01:27 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
