Snowblower Chute Clogging - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 08:37 AM   #16
Rewards Points: 5,336
Some guy on LI just had a few fingers put back on after sticking his hand into a gas powered snowblower that was not running. According to the article, the engine had some residual torque in it and it "let go" when he tried unclogging it.
I alway use a broom handle to clear the chute. Too old for, "Stumpy" as a nickname.
Ron
Old 01-15-2011, 08:51 AM   #17
A Little Of Everything
Rewards Points: 1,364
Ron
Weird.
I'm all for safety - a good share of which is simply not being stupid. Simple things go a long ways.
But a non-running snow-thrower, taking a guy's fingers off, seems very odd to me. First of all, the most a non-running engine is going to do is release compression. The engine turns one-half, to one rotation. Second, the paddles on those snow-throwers (unless it's a really old one) are rubber. Not exactly sharpened steel. Also, is there anybody who blows snow without gloves on his hands?
I'm certainly not saying a guy didn't lose his fingertips, or that it can't happen. But wow, that's an extreme case of a lot of little things going wrong all at the same time.
DrHicks is offline   Reply With Quote
Old 01-15-2011, 09:01 AM   #18
joed's Avatar
Rewards Points: 13,712
Ron
Clogged chute is a different story. I could see the auger or chute being under pressure if it was clogged. We were not discussing clearing clogged chutes. We were discussing checking for broken shear pin.
Only small snow throwers have rubber paddles. The machines I was referring to are two stage with metal augers and a metal impeller to throw the snow.
Old 01-15-2011, 09:32 AM   #19
KemoSabe
loneframer's Avatar
Always assume a gun is loaded and always assume that a machine you don't fully understand can dismember you.
True, a machine that isn't clogged and not running is assumed to be harmless, but I'm not an authority, so I'll err on the side of caution and won't put my fingers where they don't belong.
loneframer is offline   Reply With Quote
Old 01-15-2011, 09:36 AM   #20
Right.
I usually take a short stub of a 2x4 and tap it in between the auger & housing. That way, even if something was so inclined to spin, it can't.
So far I have all my fingers (and they're crossed!).
Old 01-15-2011, 12:49 PM   #21
A handy tool for clearing ice from around the impeller is a the wheel wrench from your car.
Its flattened end can be used to chip away the ice.
You can even tap the chute with the wrench end, to loosen any snow thats stuck there.
Old 01-15-2011, 03:15 PM   #22
Framing Contractor
That's exactly what we're discussing. Read OP's first post.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-15-2011, 03:33 PM   #23
joed's Avatar
We were discussing why it was clogging, not how to unclog it.
Old 01-15-2011, 03:45 PM   #24
Framing Contractor
Bottom line here. I was dumb enough to stick my hand in the chute whlie it was running and broke three fingers. I did that for six years never had a problem, never heard of anyone having a problem because I thought once you let go of the lever the impeller blades and auger blades stop spinning. I was wrong.
After that going through therapy for 3 months and meeting people there, talking to people everywhere, strangers all over the place. I found out three people did the same thing I did cleaning the chute BUT the engine was OFF. 99% of the people I talk to does the same thing using their hands to clean the chute.
For some reason when the snow clogs the chute even when the engine is off the impeller blades can turn. I don't care what any of you say about it not being possible because the people who it happened to with the engine off aren't lying.
So if there is anyone here with any sense that I could help, DO NOT USE YOUR HAND TO CLEAN THE CHUTE OF A SNOW BLOWER ON OR OFF, PLEASE!!
Joe Carola
Old 01-15-2011, 04:16 PM   #25
I can certainly understand how the blower assembly could engage with the engine running. But with the engine off just baffles me.
Of course, I'm thinking of 2-stage blowers. Maybe the single-stage are set up different.
Even so, I'm glad your hands are alright!
Old 01-30-2011, 12:12 PM   #26
I had my ring finger "pulled" off on December 21st and crushed my middle finger. I had a partial seizure and my hand went into the chute. There were able to reattach the ring finger and put the middle finger back together. However, I have nerve damage not only in the fingers, but the whole hand too. Be careful everyone.
jmorrill2 is offline   Reply With Quote
Old 01-30-2011, 02:49 PM   #27
joed's Avatar
Was the engine running or stopped?
Snowblower Electrical Question TimKLL Automotive Repairs 3 01-20-2011 07:10 PM
Snowblower Repair FF_Thor General DIY Discussions 0 11-29-2010 03:51 PM
Angled Laundry Chute Fox Remodeling 10 06-01-2010 11:09 AM
jammed snowblower Dee_M General DIY Discussions 11 11-27-2008 11:19 PM
Toro SnowBlower 521 metallic sound mteach General DIY Discussions 1 12-13-2007 12:27 PM
