Snow Blower Keeps Stalling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 03:42 PM   #1
Rewards Points: 123
Snow Blower keeps stalling
Why does my snow blower keeping stalling on me? I can not run it in normal I have to have the choke out or it will stall on me. Any help would be appreciated.
jerry1967 is offline   Reply With Quote
Old 02-22-2010, 03:47 PM   #2
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Sounds like a carburetor problem. Yank it off, take it apart & clean if if you are up to it. If you are loking for a quicker fix, try adjusting it.
CoconutPete is offline   Reply With Quote
Old 02-22-2010, 04:48 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... You've got Crud in the fuel,.... A carb rebuild might do it, or it could be the tank, or lines...
Bondo is online now   Reply With Quote
Old 02-22-2010, 09:51 PM   #4
I would get that looked at or get a new one.
Fraser20 is offline   Reply With Quote
Old 02-23-2010, 09:20 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
You're not using last years gas in it are you? If so, dump it and put fresh gas in it. Replace the fuel filter while your at it.
Old 02-23-2010, 09:59 AM   #6
Rewards Points: 5,336
This is advice consistant with your other posts.
Ron
Old 02-23-2010, 12:35 PM   #7
Dont run it with the choke out or you will burn the valves
antlerdancer is offline   Reply With Quote
Old 02-23-2010, 01:22 PM   #8
Rewards Points: 123
I have a can of old gas and the gas in the snow blower is old so I will drain that and put new gas in. How do I get rid of old gas?
Old 02-23-2010, 03:32 PM   #9
Put it in you cars tank and use it up. The old gas will be mixed in with the car gas and you won't have any issues.
Ron
Old 02-23-2010, 11:31 PM   #10
Rewards Points: 123
Ron
The gas for the snow blower is mixed with oil. Would this hurt the car if I mixed them. I am only talking about 2 gallons.
Old 02-23-2010, 11:37 PM   #11
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
What is it mixed at? 40:1? And how big is your gas tank?
brons2 is offline   Reply With Quote
Old 02-24-2010, 09:07 AM   #12
Rewards Points: 123
yes 40:1 and the thank is 15 gallons.
MTD Snow Blower w/Tecumseh Engine Won't Start RonZarn Tools 6 09-06-2009 08:35 PM
How close to the ground should the blades of my snow blower be? J187 Landscaping & Lawn Care 2 01-28-2009 04:53 PM
snow blower randyo1 General DIY Discussions 1 01-11-2009 04:04 PM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 01:55 PM
any tricks to re-string pull starter on snow blower? whwestman General DIY Discussions 4 01-14-2008 05:29 PM
