Snow Blower Drive Belt Replacement Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2008, 11:18 AM   #1
Snow blower drive belt replacement help
I have a Craftsman 5.5HP snow thrower and am trying to replace the drive belt. I've been successful up to the point where I am supposed to "grasp the idler pulley and pivot it toward the right". This would allow me to slip off the auger belt then the drive belt. The illustrations in the manual are not clear and I've tried everything but can't determine which is the idler pulley. Can anyone help guide me? Many thanks! We're due for 6 - 12 inches of snow tomorrow!
lwhiten395 is offline   Reply With Quote
Old 01-13-2008, 12:19 PM   #2
Res Ipsa Loquitur
In most (but not all!) drive belt situations it is the pulley in between two others (at opposite ends) that acts as the idler pulley. It could either be on the outside (most likely) or inside of the belt and puts pressure to keep tension on the belt. I had a Craftsman from many years ago that had an idler that was just a small pulley about 2" in diameter on a bracket with two bolts holding the bracket. The pulley rode against the outer edge of the belt.
handyman78 is offline   Reply With Quote
Old 01-13-2008, 01:01 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.........
It's the Spring-loaded, Spring-positioned 1.................
Old 01-14-2008, 06:01 PM   #4
thanks - I located the idler pulley but can't pivot it to slip off the auger belt. I hate to think it's because I'm a girl....but maybe I need a little more strength!
Old 01-14-2008, 08:33 PM   #5
Res Ipsa Loquitur
Any visible bolts holding it in place? That could be why it can't be pivoted.
Old 01-15-2008, 04:14 PM   #6
I must have the same Sears Craftsman 5.5hp snow blower -- my drive belt (on a month-old machine!!) also just broke. And I too am staring down the barrel of a 4-6 inch snowfall in less than 48 hours (I live in southern Wisconsin). When I took the top cover off to survey the problem, my idler pulley pivoted to the LEFT (the opposite of the instructions) -- it moved fairly easily, with hardly any force. Maybe there's a chunk of crap lodged in there (which may have been why your belt broke)?
AneurysmBoy is offline   Reply With Quote
Snow Blower Pull doesn't have tension Camper147 Tools 17 02-03-2015 08:52 AM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Snow Blower Repair Labrador General DIY Discussions 5 06-03-2008 01:26 PM
any tricks to re-string pull starter on snow blower? whwestman General DIY Discussions 4 01-14-2008 05:29 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 04:42 PM
