Smoke Detectors - Ionization Vs. Photoelectric - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 12:32 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Smoke Detectors - Ionization vs. photoelectric
I'm getting ready to buy smokes and CO detectors for my 2-story addition project....so I've been doing the research....came across this bit of info from NFPA.
Ionizaton vs Photoelectric Detectors
blurb from it...
Ionization smoke detection is generally more responsive to flaming fires.
How they work: Ionization-type smoke alarms have a small amount of radioactive material between two electrically charged plates, which ionizes the air and causes current to flow between the plates. When smoke enters the chamber, it disrupts the flow of ions, thus reducing the flow of current and activating the alarm.
Photoelectric smoke detection is generally more responsive to fires that begin with a long period of smoldering (called “smoldering fires”).
How they work: Photoelectric-type alarms aim a light source into a sensing chamber at an angle away from the sensor. Smoke enters the chamber, reflecting light onto the light sensor; triggering the alarm.
So....what I'll be doing....putting in combination CO & Ionization detectors in near the combustin source....and photoelectric detectors in the bedrooms...
Just wanted to share.
ddawg16 is online now   Reply With Quote
Old 07-26-2012, 10:45 AM   #2
Rewards Points: 3,130
Not a bad idea. Don't recall where it was, but I once lived in a place where both types were required by code.
Old 07-26-2012, 12:27 PM   #3
Rewards Points: 150
To me, linking them together is more important than their type. I have several of the talking Onelink's from First Alert. A voice tells you where in the house the smoke or CO was detected.
Except for the time I was using a nail gun in my garage at midnight and kicked up some dust near the smoke alarm. Every alarm inside the house sounded... the ol' family was not pleased.
silversport is offline   Reply With Quote
Old 07-26-2012, 12:47 PM   #4
JOATMON
ddawg16's Avatar
What? Family has no sense of humor?
I totally agree with the interlinking....but it looks like I'll go with the Kidde....I like the voice feature along with the hardwired interconnect....I figure it will be more reliable in the long run vs wireless.....I have enough RF stuff going on in my house already.
Kidde also has the relay module I can add that would allow me to interface it to a central alarm system.
As I do my wiring, I'm also putting stuff in place that will allow me to alarm/monitor/automate at a later date.
For now....one task at a time...a couple of years from now when I start running out of projects, I'll do the automation thing.....
Test your smoke DETECTORS! Leah Frances Safety 15 11-08-2012 07:05 AM
adding new wired smoke detectors to existing wired smoke detectors CapeCod153 Electrical 9 06-21-2012 05:03 AM
Questions on installing Smoke Detectors danielrg Electrical 10 08-30-2011 12:08 PM
Smoke Detectors on Different Circuits Mililani Electrical 13 10-17-2010 06:35 PM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
