Smoke detector will not shut up!
This freaking thing is going out the window! Few things are more immediately irritating that a smoke detector that alarms for no reason.
Brand new First Alert (BRK) SA720. Mount the ring, plug in the battery (the right way), as soon as I snap it up into the ring, it starts alarming and will not shut up, even when I press the button. I have to pull it back down and pull the battery out. Why the heII is this thing only going nuts when I mount it? Maybe the house is on fire and I don't know it yet. |
Might wanna check on that first. A house ablaze is, as they say in some circles, a "buzzkill". |
Just replace it with another one and see what happens.
If there's anything inside the unit blocking the sencer it will set it off. |
Brand new, does not work, hello. Take it back were you bought it and have the store replace. Before you leave, make sure that it works.
The floor of my building still smells after weeks. Idiot in the corner decided he could not handle his smoke detectors going off either. So he disabled even the central ones in his space that would trigger Chicago Fire to respond in a timely manner. They did but not until people saw flames from across the street and the hall detectors went off.
Do you smoke? He did and apparently shut his detectors off because he smoked really heavily. $650K worth of condo gone know. All of us near screaming at management to please fix the stench of everything known to man, including a man, smelling like it burned a month ago. Never disable a fire detector. You can clear the sensors on most by waving fresh air past them. Worst that could ever happen is a fire department responds and catches you smoking something or trying a blackened fish recipe. Yours might be wacked so exchange it. Good advice too. If you are a smoker, blow some through it. If it goes off, maybe it is trying to tell you something. You know smokers have found the electronic way for the habit at about $2.50 a pack for nicotine cartridges. I think the real deals go for $10-12 a pack here. No judgement. |
Sdester, wasn't this the one before the big one last week in the high rise up in Chi Town? At least your idiot did not decide to leave the door propped open, so that the animals could escape, in turn causing an innocent to lose her life.
Idiot was a true idjut and a heavy smoker. He disabled every smoke detector after routine fire inspections because he couldn't handle the things squeeking. Chicago Fire popped some very expensive windows around the corner of my building to help with the smoke. They checked regularly to make sure I and others were alright. And I have almost given up on people. I will rescue animals in a second. |
Wet towels never help. Of course, if they installed the smoke escape hoods that the Navy uses, people would either never PM the things, or the residents that are into smoking weed, would use them, or worst yet, they would be found in pawn shops up there. If it was me, and I lived in a high rise, I would have a SCBA (Self-Contained Breathing Apparatus) in my unit, just in case, due to you never know.
take it off the ceiling and mount it in hand see if it alarms....
So we played with it for a bit and it seems that if you don't turn it all the way into its mount, it quiets down. Mount it, it yells. Back it off a little counter-clockwise in its ring, and it behaves. This is a complete new one for me; never seen a detector act this way. Weirdest thing.
At any rate, I don't trust it. Back to the store with it. Thanks, all |
They have started gutting the corner unit that was torched. What a mess. Weird seeing people in hazard suits on a daily basis. |
two things. 1. dust can make it go off. had this issue with my own. 2. if the air is warmer or colder in are above the alarm. for example the temp of the room vs the temp of the attic. big diffences between the air temp will cause it to go off. it is a pain in the a$$ to try to fix these things at 3am when they always go off
even during remodels it's needed more...hearing about that CT Christmas Day horror of the 3 daughters and grandparent. the contractor BF and where the fireplace embers were actually removed to at 3am Christmas Day and the entire place went up in 2 hours.commercially on buildings dust maint. on them is a routine like filters changes
| All times are GMT -4. The time now is 02:14 AM. |
