Smoke Alarm Under Drywall
The glass to the ceiling, or stethoscope works in finding the culprit. Then you just have to cut a hole in the drywall, pull to place in a old work box, so the detector is on the ceiling, not behind it. Now the other curious question is, how many junction boxes are hidden behind the ceiling and walls that were dry walled.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
